Author: Subject: Titan Roller Barrel Throttle Bodies and TPS position
ChrisJ15
posted on 1/6/14 at 11:28 AM Reply With Quote
I cant get my Throttle position sensor to return the correct range on my Titan Roller Barrel Throttle Bodies.
The Omex stuff says get something between 0 and 255 for the raw value.
Whichever way round I mount the TPS is goes over the 255 and starts at 0 again and there isnt enough adjustment top get it into range.
It looks like I may be able to remove the end plate of the Titan TBs and rotate that to get the correct range.
Does anyone know if this is OK? I dont want to undo the end and have 50 parts shooting out over my garage floor!
[Edited on 1/6/14 by ChrisJ15]
Nick_TitanMsport
posted on 1/6/14 at 05:18 PM Reply With Quote
Hi Chris.
I'm not sure off the top of my head but will check this with a designer tomorrow and let you know. What TPS are you using.
ChrisJ15
posted on 1/6/14 at 05:22 PM Reply With Quote
Hi Nick,
Many thanks, that's much appreciated.
Its a RP5110-100 from Active Sensors.
Regards,
Chris
Nick_TitanMsport
posted on 3/6/14 at 01:39 PM Reply With Quote
Hi Chris.
if you undo the 6 bolts you should be able to rotate to suit your tps without having to remove the end plate.
so im told. if you need anymore help give me a shout 07741249957
cheers.
ChrisJ15
posted on 3/6/14 at 01:44 PM Reply With Quote
That's great, many thanks for finding out for me Nick.
