Author: Subject: Stat syn'd on omex 600
donn006
posted on 21/6/14 at 09:12 AM Reply With Quote
Hi I'm needing help I've just got my ecu back from being repaired and have fitted it with base map and try end starting it but won't start , further investigation reveals that I'm getting a crank signal but the ecu is saying stat syn'd off I've gone thro omex fault graph and get as far as advance menu alter syn options mx time but but can't seen to find the advance user menu
Jenko
posted on 1/7/14 at 09:09 AM Reply With Quote
I can't help directly, but have found Omex very helpful in the past. Just try sending them an email with as much detail as possible.
MY BLOG - http://westfieldv8.blogspot.co.uk/
donn006
posted on 1/7/14 at 10:38 PM Reply With Quote
Sorted it the ecu had the early software installed ,sent ecu back to omex and they upgraded the sostenuto ware
