Author: Subject: WANTED, sealed M10 rivnuts...
fha772
posted on 29/6/14 at 11:16 AM Reply With Quote
Hi all,
As the title says, I'm after some M10 size sealed/capped rivnuts, they need to be the sealed type as they are going in the roof of my lorry cab.
I only need about 6, but will buy upto 20 if I need to.
Any help would be greatly appreciated.
Cheers Frank.
http://www.ppcmag.co.uk/forum/viewtopic.php?f=47&t=6743&start=105
FuryRebuild
posted on 29/6/14 at 12:34 PM Reply With Quote
take a look at this post I made - these guys do stainless backing washers.
Let me see how many I have left later, if you need half a dozen, I may have some. Otherwise if you need to buy a load and only need six, I'll buy most of them off you because I may need a bunch more.
www.furyrebuild.co.uk
ReMan
posted on 29/6/14 at 03:28 PM Reply With Quote
These. Mixed of Pack Rubber Backed Stainless Steel Washers 5mm M5,6mm M6,8mm M8 x100
But they're not sealed rivets?so depends on your application it they will do or not?
Didn't ever realise you could get sealed rivnits. Shop on ebay says he does m10 but not listed in checkout
edited as I looked and don't have any m10
[Edited on 29/6/14 by ReMan]
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
ste
posted on 29/6/14 at 10:13 PM Reply With Quote
Found some for you. Very hard to track down, but you need to be searching for the correct terms as 'sealed' doesn't bring back any results for M10.
They are called 'closed end' and this place does them in 10 packs for under £4
http://www.rivetwise.co.uk/productrange/nutdetails.asp?nut=m10frc_xl_s_273
ste
posted on 29/6/14 at 10:14 PM Reply With Quote
To properly seal them you will need to put sealer under the head as you set them.
fha772
posted on 30/6/14 at 02:34 PM Reply With Quote
Thanks for the replies guys, I've just bought some off eBay.
Cheers Frank.
