Simon
posted on 14/7/14 at 09:56 AM |
Temporary concrete drive widening
Folks,
Following on from the garage ext and porch at front of house, we now need to widen the driveway.
It will be done properly next year (imprinted concrete perhaps) but need more room on drive now. What would I get away with for a minimum thickness of
concrete for around 8 months? Was thinking iro 3 inches and left for a week to harden off.
Not a large area, perhaps 3m long by 1m wide. Only have the wife's ZR or my TF on it
Simon
tegwin
posted on 14/7/14 at 10:00 AM |
The thickness of the concrete is not the issue, its the quality of the base onto which the concrete is laid.
If its just a temporary thing I would dig out down to solid ground where I wanted to widen the drive. Then fill with hardcore and top with a suitable
gravel making sure to compact it properly.
www.verticalhorizonsmedia.tv
stevebubs
posted on 14/7/14 at 10:02 AM |
watch out for regs on driveways....they changed a while ago; you may have to use a permeable surface...
pewe
posted on 14/7/14 at 10:42 AM |
Why not just put down four paving slabs (i.e. one each wheel) set on a gravel/spotted concrete base?
Just ensure the part under the vehicle is well drained though.
HTH.
Cheers, Pewe10
posted on 14/7/14 at 10:53 AM |
We had to extend one edge of our driveway three years back after the verge got badly chewed up during the the extremely snowy winter. We used
gravel retaining grids and red whin chips quick and easy to lay and it has worked extremely well, the chips stay put.
If you do a Google you will find a number of different grid/matting systems on the market.
[Edited on 14/7/14 by britishtrident]
Simon
posted on 14/7/14 at 03:53 PM |
At the moment we have grass, crazy paving, concrete, red tarmac and a bit of leftover ballast gracing our drive.
House looks quite smart apart from ground. Haven't got the money to do drive till next year so the crazy paving and ballast are all going to be
replaced with a nice slab of concrete.
So long as it lasts till late spring that'd be grand.
When drive gets done, all groundwork will be done properly then, in the meantime just need to know if 3" or so will suffice
Simon
blakep82
posted on 14/7/14 at 04:08 PM |
What about this stuff?
http://www.ebay.co.uk/itm/like/251305253022?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=t&adtype=pla
&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108&ff19=0
Can be taken back up later, and back on ebay
About £60 for the area you need
This ones cheaper
http://www.ebay.co.uk/itm/Plastic-Grids-Garden-Grass-Paving/281373641148?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26
ao%3D1%26asc%3D24133%26meid%3D8311915125227368246%26pid%3D100005%26prg%3D10245%26rk%3D2%26rkt%3D6%26sd%3D251305253022&rt=nc
A lot less work than concrete, and way cheaper too. Grass grows through it so you don't actually see it, but its a good firm ground that
won't turn to mud
________________________
Texan
posted on 14/7/14 at 05:06 PM |
Make it easy on yourself and just use bricks.
They'll be much easier to put down and take back up again. Plus you'll find hundreds of uses for the bricks afterwards.
Getting the old concrete out from a temporary pour will be an absolute bitch.
I drive therefore I am.
talkingcars
posted on 14/7/14 at 10:38 PM |
In one corner of the yard we have some unconcreted ground, when we started to use it for storeage 5 years ago a metre wide path of the plastic grid
was laid down the middle, it is driven on everyday with 5 tonne fork lift trucks yet it still holding, I regularly get stuck if I go off the side but
not on the grid.
