Author: Subject: IVA test question - steering
killerferret666
posted on 20/7/14 at 10:49 AM Reply With Quote
How do they test that the steering can be turned in both directions as designed and not fowl on anything unless designed to be a steerin bump stop as such..
Reason I ask is, when the car is sat on the wheels as its designed it does not fowl at all, however when jacked up the wheels tyre can catch part of the chassis by a mm or two.
So I wondered do they test with the front of the car in the air or test by turning the wheel with the wheels on the ground.
Building DDR GT4
Miami Gt4 Blog - Click Here
renetom
posted on 20/7/14 at 11:29 AM Reply With Quote
Hi
Did ours on the ground.
Good luck
René
zx12r dug
posted on 20/7/14 at 12:21 PM Reply With Quote
Hi.My four previous builds were tested on the ground
snapper
posted on 20/7/14 at 01:57 PM Reply With Quote
They use turn plates so beware
Perhaps a couple of jubilee clips in side the steering haters could help
I eat to survive
I drink to forget
killerferret666
posted on 20/7/14 at 02:37 PM Reply With Quote
Sounds like good news if on the ground or potentially plates, the key is the cars weight is on the suspension so the coilovers compress and hence bring the wheels higher into the arch.
Could you explain to me the jubilee clips inside the steering haters, being honest that doesn't mean much to me. Thanks
Building DDR GT4
davidimurray
posted on 20/7/14 at 02:40 PM Reply With Quote
Mine was done in the air, but up on the drive on lift so weight was on suspension.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
skov
posted on 20/7/14 at 05:53 PM Reply With Quote
Think he meant jubilee clips inside the steering gaiters
Basically, pull the gaiters back to reveal the ends of the steering rack. Fit jubilee clips to the end of the rack to act as lock-stops. Re-fit gaiters and hope IVA man doesn't realise what you've done
I personally wouldn't recommend it. I tried, but the jubilee clips failed before I'd even booked the IVA. They don't handle much in the way of sideways bashings.
[Edited on 20/7/14 by skov]
