Author: Subject: Canems, which wideband lambda and controller?
fha772
posted on 22/7/14 at 04:03 PM Reply With Quote
Hi all,
I'm looking for a wideband lambda sensor and controller, to use with my Canems ecu.
Can anyone suggest what to get, and where from?
Cheers Frank.
[Edited on 22/7/14 by fha772]
http://www.ppcmag.co.uk/forum/viewtopic.php?f=47&t=6743&start=105
posted on 22/7/14 at 04:21 PM Reply With Quote
I've just fitted an AEM wideband to my bike, seems to do the job very well.
dave_424
posted on 22/7/14 at 04:50 PM Reply With Quote
I use an Innovate MTX-L, cheapest one out there when I was looking and great quality. Waterproof and you can change the colour of the gauge background and bezel
SPYDER
posted on 22/7/14 at 06:01 PM Reply With Quote
I use the Tech Edge 2J2 wideband. Five years on and no problems.
Ugg10
posted on 23/7/14 at 01:49 PM Reply With Quote
I'll be keeping an eye on this thread as I will be needing a Wideband system in the next few months to go with an Emerald ECU.
As far as I can see I have four options -
Innovate MTX-L - integrated guage and controller - easy to fit
AEM 6in1 30-4100 - similar to above
Innovate LC2 + gauge - slightly lass tidy wiring
PLX DM6 plus gauge - similar to LC2 but gauge looks quite fancy with the touch screen
All are around the £150 mark give or take a bit so any thoughts on which is better in terms of life and stability just in case I decide to run the engine closed loop would be greatfully recieved.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
