Author: Subject: Exterior Pre IVA check - Picture Heavy
killerferret666
posted on 11/8/14 at 07:01 PM Reply With Quote
I've broken it down into interior/ under shell and exterior for a few reasons.
1. I know I still have bits to do on the interior so dont want to waste peoples time
2. this is a different build to most so sure some people will pick up bits in different areas
3. Gives me some time to correct these bits
With that said things I noted myself when uploading and corrected or will correct;
1. Forgot to put wiper arm nut cover on - now on
2. Fender for front wheel actually stops about 200mm above centre line of wheels, IVA Manual specifies 150mm - ordered some plastic PVC sheet and will fit in the rear of the front arch and trim the edge.
things just to note;
* A 100mm ball cant get between the wheel and the arches
* Wing mirrors will be set up before test (cant get in the garage with them sticking out)
* Bodywork is done just to fit, Bodyshop will align it all
Anything you guys spot just post. cheers!
Building DDR GT4
Miami Gt4 Blog - Click Here
austin man
posted on 11/8/14 at 08:04 PM Reply With Quote
air intake will require trimming due to radius / sharp edge
killerferret666
posted on 11/8/14 at 08:27 PM Reply With Quote
Thanks....more sanding ...great
Building DDR GT4
snapper
posted on 11/8/14 at 08:58 PM Reply With Quote
One of the advantages of full bodywork is the there is little to worry about regarding edges
I would however look closely at rear vision
Light height and things like side repeaters
As this is an unusual car ( what is it?) you may be better off going to IVA and walking away with a to do list
I eat to survive
I drink to forget
The Black Flash
posted on 11/8/14 at 09:00 PM Reply With Quote
Assuming all of the various moulded edges on the body are radiused (can't really see), then there doesn't look to be much as it's all covered in
Is the edge of the bottom plinth of the light stalks 2.5mm? Or does the ball not touch?
killerferret666
posted on 11/8/14 at 09:24 PM Reply With Quote
Rear vision is reason for the mirrors on strange high and wide mounts and the glass is convex as well. With no interior mirror it is something I've done all I can at the moment.
Light height all checked, indicators ok, headlights 510mm to bottom edge of lit area.
It's a DDR MOTORSPORT GT4 and I had same thoughts as you, I'd got to the point where a list will be more helpfull.
Building DDR GT4
killerferret666
posted on 11/8/14 at 09:27 PM Reply With Quote
Yep they are all moulded and turned in.
Not too sure what you mean about light stalks? Do you mean the front light covers, if so it only sticks out about 2mm so just needs to be blunted.
Thanks all for feedback all helpful!
Building DDR GT4
gavin174
posted on 31/8/14 at 08:27 AM Reply With Quote
Is rear fog light 90 degree to the road and "f" marked....
nice looking build.....
[Edited on 31/8/14 by gavin174]
killerferret666
posted on 31/8/14 at 08:48 AM Reply With Quote
Yep learnt that off someone else's pre IVA Photos, so all good on that one and it is F marked as well.
thanks
Building DDR GT4
