Author: Subject: Griffin inlet plenum swap
Sierra
posted on 22/8/14 at 03:57 PM Reply With Quote
But of a long shot but thought I'd try anyway.
I've currently got a griffin plenum and would like to swap for a spencer ashley type plenum. Only reason is I need one that's angled upwards for clearance on the supercharger.
big_wasa
posted on 22/8/14 at 08:43 PM Reply With Quote
If I had one I would bite your hand of as they are NASTY.
pepper performance / Spencer Ashley = same thing.
Sierra
posted on 22/8/14 at 08:49 PM Reply With Quote
I've heard that they have changed and just awaiting pictures from them so shall see.
mark chandler
posted on 22/8/14 at 09:27 PM Reply With Quote
Cannot you get someone to modify what you have, it sounds like you just need a bit of metal added or a wedge cut out to change the angle so saves messing around with injectors, loom, fuel rail etc?
big_wasa
posted on 22/8/14 at 09:51 PM Reply With Quote
Ok I would love to see them.
Sierra
posted on 22/8/14 at 09:56 PM Reply With Quote
I did look into it but the only way would be to cut it at the flange and angle the 4 ports about 25 degrees, the problem would then be that the injectors would be at a strange angle and may mess things up.
mark chandler
posted on 23/8/14 at 08:02 AM Reply With Quote
My injectors are running upside down without any problem, with 3-4 bar of pressure behind them they do not care.
Get a 90 degree mandrel bend, chop it into 4 even parts and weld in
