Author: Subject: Radiators
CosKev3
posted on 23/8/14 at 09:37 AM Reply With Quote
Radiators
Morning
Anyone knowledgeable on cooling?
Would a alloy down flow rad with a core size of 32w x18h x5d offer more cooling than a standard cross flow rad with a core size of 33w x31h x2.5d?
Would the alloy rad cool a R1 BEC well enough?
The standard core size above is the standard R1 rad.
Cheers.
cliftyhanger
posted on 23/8/14 at 09:50 AM Reply With Quote
Doubling depth will not make up for halving area.
Double depth maybe a 25% area reduction? Bit of a guess that.
posted on 23/8/14 at 11:48 AM Reply With Quote
Thick core requires more air pushed through it to cool efficiently.
More closely packed fins require a greater air pressure pushing the air through the rad to show a cooling gain.
CosKev3
posted on 23/8/14 at 03:36 PM Reply With Quote
Ok cheers
Halving area?
It's a long way off half the area!!!
matt_gsxr
posted on 23/8/14 at 08:05 PM Reply With Quote
Polo radiator is something of an accepted standard (and fine for BEC's).
Polo rad dimensions are approximately 19inch by 13inch.
So I'd guess you'd have plenty of cooling.
Matt
p.s. the rad in the bike is even smaller.
http://jpsc.org.uk/forum/
daviep
posted on 23/8/14 at 08:40 PM Reply With Quote
Originally posted by CosKev3
Ok cheers
Halving area?
It's almost exactly half the frontal area, 56% ish
posted on 23/8/14 at 09:17 PM Reply With Quote
With heat exchangers you have to look at total surface area that is total area of the tubes and the fins.
A rad with closely packed fins like and old style Mini brass rad has a lot of heat transfer area but presents more blockage to the air flow compared to for example a Cortina/Escort rad which has less closely pack fins.
A Polo alloy is very efficient it has a good compromise between fin density and air flow.
CosKev3
posted on 24/8/14 at 08:26 PM Reply With Quote
Looking inside the alloy rad I've noticed its got three rows of cooling tubes deep,not just a single 5cm tube,so this will help cooling?
Ok cheers
Halving area?
Am I being thick?
Surely 50% of 33w x31h is 16.5w x15.5h?
How can 32w x18h=56%?
mark chandler
posted on 24/8/14 at 08:34 PM Reply With Quote
I look at things more simply, the standard rad on a R1 is a tiny little affair, granted that on a bike it will not be worked as hard at any given speed but most small car rads are up to the job.
I run a polo rad, pre turbo it was fine, post turbo I needed to add an oil cooler and sort out the ducting to prevent air leaks.
Slimy38
posted on 24/8/14 at 08:42 PM Reply With Quote
Am I being thick?
56% is right. 33 x 31 surface area is 1023, 16.6 x 15.5 surface area is 255, which is 25% not 50%.
[Edited on 24/8/14 by Slimy38]
posted on 25/8/14 at 07:10 AM Reply With Quote
Am I being thick?
But that is the frontal area not the heat transfer area.
The depth and fin density also have to be allowed for.
