Author: Subject: Toyota 4age
ian.stewart
posted on 26/8/14 at 08:46 PM Reply With Quote
Toyota 4age
Im having a serious rethink on my BEC engine car as I Started the Bec engine for the first time which promptly seized solid after 30 seconds, yes there was oil in it.
So it took about 10 mins to decide 4AGE,
What have you lot in my computer got that will help me on my way converting my car to 4age, I am starting from scratch, so engine gearbox, conversion bellhousing, anything really,
Something different, Very different..............
twybrow
posted on 26/8/14 at 10:23 PM Reply With Quote
I'd be wanting to know why your last engine seized before leaping into a different install.... Got to be worth an evening tearing the old lump apart and tracking down the culprit. I can't help with the 4AGE bits - sorry and good luck!
t11
posted on 27/8/14 at 06:00 AM Reply With Quote
re 4age
Hi if you are after 4age bits try Martin Jones @RAW 01432 371169 he may well still have a few bits lying around....Gordon
Worzey
posted on 27/8/14 at 07:48 AM Reply With Quote
As above. RAW provided the supercharger upgrade on my 20v 4AGE and their service was first class. Martin was exceptionally helpful throughout the build.
They should have all of the bits you need.
Caterham R400
Camber Dave
posted on 28/8/14 at 09:50 AM Reply With Quote
Have a look at my post from Nov last year
Most of the stuff is still in the shed and I would be glad to see it go to a builder.
ian.stewart
posted on 28/8/14 at 05:12 PM Reply With Quote
U2U sent
ian.stewart
posted on 29/8/14 at 06:00 AM Reply With Quote
Dave, don't know if you have replied, I cant open my U2U, Ill phone sometime this morning,
Camber Dave
posted on 29/8/14 at 07:46 AM Reply With Quote
Ian
U to U sent
D
Ugg10
posted on 29/8/14 at 07:55 AM Reply With Quote
An alternative to the 4AGE is the Ford Sigma/Zetec SE engine, worth looking at. Now used by Caterham and Westfield as their standard fit engines, also found in the Sylva J15/R1OT. Lots of tuning bits available.
All ally engine, very light (my 1.7 is less than 100kg with all ancillaries), one of the best flowing heads around, the 1.6 is found in the Puma, Fiesta and Focus so plenty available/cheap, with cams, rod bolts and valve springs on TB's/ECU and a decent exhaust it will make 180hp all day at 8k rpm with a decent amount of torque.
Just a thought.
[Edited on 29/8/14 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
