coombed
posted on 6/9/14 at 02:59 PM |
Mysterious hole in Pinto block, help!
Hello all,
Can anyone tell me what this hole is on the bottom of the engine block, towards the back, under the exhaust manifold? The engine is a 2l Pi to.
Duncan
You don't stop playing when you grow old, you grow old when you stop playing!
CosKev3
posted on 6/9/14 at 03:19 PM |
Looks like a breather outlet to me?
DRC INDY 7
posted on 6/9/14 at 03:21 PM |
Turbo drain to sump.
Puddle Dodgers Club
sonic
posted on 6/9/14 at 04:56 PM |
maybe the dipstick hole, should have a tube in it if it is.
ian locostzx9rc2
posted on 6/9/14 at 04:58 PM |
Dipstick tube? End normally has a rubber pipe that the dipstick sits in it.
[Edited on 6/9/14 by ian locostzx9rc2]
DRC INDY 7
posted on 6/9/14 at 05:19 PM |
The dipstick is on the inlet side of the engine.
The bit in question is the turbo oil drain back to the sump just make sure you blank it off if its open.
Puddle Dodgers Club
Andy S
posted on 6/9/14 at 08:19 PM |
As above - a drain back - would usually have a blanking plug in it as a standard engine.
coombed
posted on 6/9/14 at 09:55 PM |
Blank made, hole sorted! Thank you all for your input!
