Author: Subject: Sierra rear hub nuts
mark_UK
posted on 21/11/04 at 12:12 PM Reply With Quote
Anyone know what size socket is required for the rear hub nuts ?
James
posted on 21/11/04 at 12:41 PM Reply With Quote
41mm I believe.
I'd recommend getting an impact grade one- you'll need it!
Good luck getting it off. Remember the near-side has a left hand thread.
All the best,
James
bob
posted on 21/11/04 at 01:10 PM Reply With Quote
yep its 41mm
mark_UK
posted on 21/11/04 at 02:12 PM Reply With Quote
Thanks, I`ll see if I can get one this week ,along with some big stilsons (its off the car)
Steve Hnz
posted on 22/11/04 at 02:53 AM Reply With Quote
Mark, rather than using stilsons with the attendant damage they do, make up a steel bar with holes to go over a couple of the wheel studs, bolt this in place & hold in a big vise while you swing on the hub nut. I made a bar in 50mm X 10mm, cutting a half moon out of the side of one end to give clearance for the socket. The one I have pictured was made for doing the pinion nut on a Land Rover but the idea is just the same, except the cut out will need to be bigger. HTH Cheers, Steve. Rescued attachment Stud bar.jpg
Steve Hnz
posted on 22/11/04 at 03:02 AM Reply With Quote
Oh hell, Can anyone tell me why when I send a nice neat 80kb jpg I get back an unwieldy 900 + kb bmp, is it my computer or some thing I`m doing. Ta, Steve.
