Poll: Mercedes track car, brake bias adjustment options [View Results]
Bias valve
Twin master cylinder bias box
Something else
Author: Subject: Mercedes track car, brake bias adjustment options
fha772
posted on 16/11/14 at 01:07 PM Reply With Quote
Hi all,
I'm just weighing up my options for altering the brake bias on my old Mercedes track car.
It locks up the rear wheels most of the time.
My options, from what I can see are, using a bias valve in the rear brake pipe and keep the original servo master cylinder, or slightly modify a BMW e30 twin master cylinder adjustable bias pedal box and lose the servo assist.
What do you guys think?
If you've got any other suggestions, please feel free to comment.
Cheers Frank.
http://www.ppcmag.co.uk/forum/viewtopic.php?f=47&t=6743&start=105
posted on 16/11/14 at 01:33 PM Reply With Quote
Depends a lot on what the bias is to start with, a valve will only work if you are over braked on rear.
fha772
posted on 16/11/14 at 02:25 PM Reply With Quote
Apart from the rear locking up, the brakes are spot on.
I've uprated every corner with bigger grooved discs all round, ebc yellow stuff pads, braided hoses, and race spec fluid.
If it wasn't for the rear locking up, the brakes would be perfect.
At Cadwell on Friday, I was out for 25-40 minutes every time with no worries about the brakes.
[Edited on 16/11/14 by fha772]
ReMan
posted on 16/11/14 at 02:47 PM Reply With Quote
I don't see why you can't put a bias valve into the rear line as you suggest, for simplicity
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
mark chandler
posted on 16/11/14 at 05:21 PM Reply With Quote
Keep it simple, bias valve
fha772
posted on 16/11/14 at 05:28 PM Reply With Quote
I'm leaning towards a bias valve, but I just wondered if it was the best option.
I'm not too fussed about the work or cost, just what is the best option with regards to performance.
fha772
posted on 16/11/14 at 09:24 PM Reply With Quote
Just 1 more question...
If I go with a bias valve, do I go for a screw, or lever type?
rdodger
posted on 16/11/14 at 09:39 PM Reply With Quote
Screw
More adjustable and less likely to be knocked/moved.
morcus
posted on 17/11/14 at 04:52 PM Reply With Quote
What you want is one of those set ups they used to have in rally cars with two separate brake pedals (Though I believe the front one overlapped the rear one so it was just rear or all) though I imagine you'd need some serious skills to be able to operate two completely separate ones (Not to mention another leg).
