Author: Subject: Recommended jet six
F1SJL
posted on 18/11/14 at 08:32 PM Reply With Quote
Recommended jet six
Evening all
Can anyone recommend me the jet size for my pinto zx9r conversion?
It's a 2.1 by the way.
19sac65
posted on 19/11/14 at 04:25 AM Reply With Quote
I did bike carbs on a zetec
Mines on 1.8mm and its running great
I know pintos are a bit more thirsty
What i did was buy a modellers drill bit kit, drilled them out to 1.6-tried it , then 1.7 etc till i got it right
I then bought a set of jets in the size ide drilled them to give as good a spray pattern as poss
Theyre weber dgav jets so less than a tenner for all 4
This was the easiest way without buying loads of jets
Well worth the faffing imo , transformed the car
mcerd1
posted on 19/11/14 at 09:15 AM Reply With Quote
most folk seem to start around 1.6mm and see how it goes from there
I think that's whats in mine, bogg bros did them for me as there best first guess to get the engine running with a trip to there rollers planned for when the cars on the road
johnemms
posted on 19/11/14 at 09:32 AM Reply With Quote
Most model drills can be way out ...
Always use a vernier - measure them them for their true size.
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
F1SJL
posted on 19/11/14 at 11:17 AM Reply With Quote
Thanks for the advice.
I'll have to have a play around and go from there. I'm going to have it set up on rollers anyway.
johnemms
posted on 19/11/14 at 11:22 AM Reply With Quote
150pc Precision Mini Micro Drill Bits, Suitable For Craft, Model, Hobby, Etc
They vary in accuracy - need to measure them before use ..
[Edited on 19/11/14 by johnemms]
mcerd1
posted on 19/11/14 at 11:56 AM Reply With Quote
it always pays to check them - but as a general rule the better brands will have better tolerances and last much longer than the cheap nasty made in China stuff
the good ones may cost £1 - £2 each, but you only need 3 or 4 drills
