Author: Subject: Show me your DIY Airbox
davidimurray
posted on 10/12/14 at 12:27 PM Reply With Quote
Picked up a cheap Pipercross viper air filter on ebay so I'm thinking about changing my sausage filter (which was tight inside the bonnet with the Pinto so will most likely be even tighter with the Duratec!) and making my own airbox and ducting to the filter/frontof the car.
Airbox will go on ZX6r carbs respaced to suit the engine.
Would be interesting to see what solutions people have come up with.
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Barkalarr
Contributor
Posts 943
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 10/12/14 at 01:38 PM Reply With Quote
This was the airbox my mate for my R1 powered Indy. We didn't have enough space beneath the bonnet and the top of the engine to reverse the original airbox, so we made a new one which started out as a piece of card.
We used the original K&N air filter which came with the bike engine, and make all the inlet holes the same size as the original.
It's pretty handy when one of your mates is a sheet metal worker by trade and bloody handy with an aluminium welder.
I'm sure he'd take orders if I asked him very nicely....
scutter
posted on 10/12/14 at 02:01 PM Reply With Quote
I was running a half under the bonnet/half out filter. Decided to just cut the bonnet for a full filter in the end. I used an old sausage filter plastic mount some alloy a friend welded and a PX600 filter.
Basic parts
Basic parts
Basic parts 2
Basic parts 2
Fitted
Fitted
Filter fitted
Filter fitted
ATB Dan.
mark chandler
posted on 10/12/14 at 03:39 PM Reply With Quote
plenum 2
plenum 2
davidimurray
posted on 10/12/14 at 07:16 PM Reply With Quote
Thanks everyone - some good inspiration there. I notice that they all look to be welded. Has anyone made one with just pop rivets?
Barkalarr
Contributor
Posts 943
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 10/12/14 at 07:50 PM Reply With Quote
If you don't want anything welded, I can make you one of these :
rick q
posted on 10/12/14 at 08:18 PM Reply With Quote
There ya go - fabricated with left over aluminium, a bought piece of filter media and bought ramtubes :-
and finished :-
[Edited on 10/12/14 by rick q]
avagolen
posted on 10/12/14 at 09:42 PM Reply With Quote
Hi, this is my airbox.
The side piece is riveted to the base and the 'lid' is screwed to a lip I mounted
inside the box with riveted angle brackets. All sealed inside with the sikaflex.
I created a silicon seal by putting a sheet of grease proof paper on the inside of the lid and
running a bead of silicone on the mounting lip. I fitted the lid loosely with it's screws and
left it for a couple of days. Once removed, the silicone had stuck to the aluminium lip
and the grease proof paper just pealed of leaving a flexible seal.
The filter can be remotely mounted if I find it necessary.
airbox1
airbox1
airbox2
airbox2
airbox3
airbox3
airbox4
airbox4
airbox5
airbox5
airbox6
airbox6
airbox7
airbox7
[Edited on 10/12/14 by avagolen]
davidimurray
posted on 11/12/14 at 06:58 PM Reply With Quote
Thanks everyone - got the grey matter churning now ...
Steve Hignett
posted on 12/12/14 at 07:45 AM Reply With Quote
I've made a couple of these myself, in 'glass, Ali and CF, but I have to say that apart from the height of it at the inlet being to short and weight of it ('cause I used to be a weight conscious freak!), that has to be one of the best air boxes I've seen...
Tell your mate he's done a bang up job with that! Especially as he probably "found" the bits of Ali too!
SH
HowardB
posted on 12/12/14 at 08:03 AM Reply With Quote
That I like
how much,...?
Howard
Dick Axtell
posted on 12/12/14 at 09:45 AM Reply With Quote
That I like
how much,...?
+1. What are aperture dimensions?
Barkalarr
Contributor
Posts 943
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 12/12/14 at 03:29 PM Reply With Quote
These are the dimensions - it's going to be between £80 and £100
HowardB
posted on 12/12/14 at 03:57 PM Reply With Quote
I think that I shall need to do some CAD, cardboard aided design to see if that will fit under the Fury bonnet,... it would be going on a silvertop,.
Howard
Barkalarr
Contributor
Posts 943
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 6/1/15 at 03:55 PM Reply With Quote
Chaps - have a look at this thread Here
