Author: Subject: Fiat steering rack drawings
designer
posted on 18/12/14 at 08:24 AM Reply With Quote
Has anyone got dimensions/drawings of the Fiat Cinquecento/Seicento steering rack?
My racks in the UK and I'm not there till Feb!!
orton1966
posted on 18/12/14 at 08:45 AM Reply With Quote
I've got one in the workshop, I'll try and run a tape measure over it in the next day or so
Brian R
posted on 19/12/14 at 02:16 PM Reply With Quote
Google came up with this. Don't know if it's any good? I'm guessing RHD would be the same dimensions.
•Operating Mode: Manual
•Driver Position: for left-hand drive vehicles
•Overall Length: 914 mm
•Mounting bores distance: 240 mm
•Input shaft height: 57 mm
•Input shaft connecting type: Splined
•Number of splines on input shaft: 17
•Input Shaft Diameter: 14 mm
•Manufacturer Restriction: TRW
•Axle Joint Length: 166 mm
•Axle Joint Thread Size: M12x1,5
designer
posted on 20/12/14 at 08:59 AM Reply With Quote
That's brilliant, many thanks.
Never found that myself! Maybe it's this French service provider I use!
