Author: Subject: TPS for Nodiz
simonrh
posted on 13/1/15 at 01:50 PM Reply With Quote
TPS for Nodiz
I want to get a basic TPS to start looking at moving to 3D mapped ignition.
I can see various TPS from various fords etc described as being clockwise or counter-clockwise in operation.
I think I am misunderstanding something though, aren't basic TPS (not fancy hall effect ones) just variable resistors and so if the rotation is the "wrong"way for my installation can I not just reverse which way round I connect the zero and the signal wires which will swap it from reading high when closed to reading low when closed and vice versa? You then just calibrae the box to suit?
The no diz instructions seem to describe how to check the continuity etc across the 3 wires to get them the right way round?
Or is there something mechanical about a TPS that I am missing that means it doesn't work like this at all.
dave_424
posted on 13/1/15 at 03:45 PM Reply With Quote
I'm not sure but I believe that some are spring loaded so that they aren't affected by and slop in the engagement of the sensor. So might only work one way.
simonrh
posted on 13/1/15 at 04:20 PM Reply With Quote
That would make more sense, ta
davidimurray
posted on 13/1/15 at 04:25 PM Reply With Quote
Yes you can just swap the wires around
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Xtreme Kermit
posted on 13/1/15 at 05:59 PM Reply With Quote
Not sure what set-up you have, but I'm sure I have an unused TPS set up for twin 40/45 in the garage waiting to go to a new home at the right price.
Mikef
posted on 14/1/15 at 02:50 PM Reply With Quote
Yep fairly certain you can swap the wires, around I used a ford Focus, one on Twin 45s. When I did a Nodiz upgrade . Did not need to swap them as it was the right way for my carbs
posted on 14/1/15 at 04:45 PM Reply With Quote
Correct!
