Author: Subject: Can I get a new plate with an old engine?
Piooly
posted on 18/1/15 at 10:12 PM Reply With Quote
So I am nearly at the end of my build. I want to register the car if possible with a new number plate, so a 2015 plate. I have not used a donner car. Everything on the car is new except the engine which has been completely stripped and enhanced and rebuilt. The engine I think is a 1986 engine.
Question is can I get a new plate for this?
do I need a Cat for a new plate?
And can my emissions be based on the original 1986 engine and not modern regs.
Thanks.
theduck
posted on 18/1/15 at 11:10 PM Reply With Quote
IVA will do emissions based on engine age, so no need for cat.
You can get a new registration with all new parts and one refurbished to as new condition part, in this case the engine. So as long as you can prove everything's new, you should get a new plate.
chrisj
posted on 19/1/15 at 06:20 PM Reply With Quote
The block of my engine was 1978 (I had to prove it with a serial number) and show receipts of the new or refurbished parts. I got the new plate and i also merely have to comply with a visual emmissions test due to the age of the engine.
Good luck.
Slimy38
posted on 19/1/15 at 06:26 PM Reply With Quote
Good luck.
Yep, I get the impression paperwork is the key. Anyone could clean up an engine and try and pass it off as refurbished, but get the receipts together and you have a much better case.
By the way, I'm guessing you already know this but the engine and gearbox are generally considered two separate things, so if you refurb the engine your gearbox will have to be new.
Piooly
posted on 19/1/15 at 10:47 PM Reply With Quote
Just out of interest has anyone ever had their car checked over or paperwork checked prior to the DVLA issuing a number plate?
From what I know the IVA test only checks for roadworthness and emissions? Unless I have got that wrong...?
loggyboy
posted on 19/1/15 at 10:50 PM Reply With Quote
Theres 2 processes -
VOSA handles the IVA -0 checking roadworthyness, but also sets emmisions levels based on engine age (they will require proof (not from manufacturer, V5 from donor etc) Then once you have a IVA certificate, the DVLA handles the registration, and its them thats needs the reciepts, and its also good to have build file of photos etc to show YOU built it as the process is different for professional builders.
Mistral Motorsport
Piooly
posted on 19/1/15 at 11:07 PM Reply With Quote
I have a big folder of receipts and build photos of everything so should be ok for that. I don't have a v5 as I didn't use a donor. Will I need to get proof of engine age via its engine number if possible.....?
loggyboy
posted on 20/1/15 at 12:35 AM Reply With Quote
I suspect it will need to come from the manufacturer. What engine?
Mistral Motorsport
Slimy38
posted on 20/1/15 at 08:54 AM Reply With Quote
I thought it had to come from the manufacturer regardless, they don't accept the V5 as proof of engine age? There's nothing on the V5 to say the engine is the original one.
Piooly
posted on 20/1/15 at 09:40 AM Reply With Quote
engine is a rover v8, how am I going to manage that one as they no longer exist...
Any ideas...?
loggyboy
posted on 20/1/15 at 10:03 AM Reply With Quote
As long as there are no notes to say the engine has been changed and the numbers on the engine match the V5 then generally its ok, the note reads:
Evidence of the date of manufacture of the engine will be required at the time of inspection to determine the emissions limits for the vehicle. The donor vehicle registration document (V5) may be acceptable evidence, where it indicates the engine to be the original engine fitted to the donor vehicle.
Mistral Motorsport
Piooly
posted on 20/1/15 at 10:58 AM Reply With Quote
I dont have a V5 document though for where the engine came from.... so dont have any paperwork unless I create some..
theduck
posted on 20/1/15 at 11:08 AM Reply With Quote
Proof of age for the engine can be done by engine number. For example, most inspectors accept the Burton catalog guide for engine age on ford engines.
davidimurray
posted on 20/1/15 at 12:26 PM Reply With Quote
Give your IVA inspector a ring and ask him how he prefers to have the proof of engine. I turned up for mine with a letter from ford and he said I didn't need to bother as he would have accepted the Burtons catalogue.
They might accept the equivalent from Rimmers http://www.rimmerbros.co.uk/content--name-Rover-V8-Engine-Numbers
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Piooly
posted on 20/1/15 at 02:16 PM Reply With Quote
ok so I have had a look at rimmer etc and my engine is a 4.6 rover v8, said to be manufactured between 1994 - 2002.
The engine bear no resemblence to the original in terms of its spec, its only the actual block thats original, crank, pistons, heads, rockets, valves are all new and highly modified. I am using using carbs and not EFI.
If I am trying to go for a new plate, from what I can find out, My car would need to conform to BET emission rules of 0.2%CO
There is no way this engine is going to meet that.
Basically am I stuffed? or will I have to register the car as a Q plate as emmissions wont matter then? I really dont want a Q plate but sounds like I might have to. A real shame considering the whole car uses new parts!!! (
Yes I suppose one could create some paperwork to say the engine is older but I imagine the testers have seen this time and again and already have a list of rover v8 engine numbers to say otherwise....????????????
Piooly
posted on 20/1/15 at 02:30 PM Reply With Quote
Also out of interest ofcourse, what does the IVA do if your engine number is missing so you cant prove what age it is? I have a receipt of purchase but that does not mention engine numbers etc...
gremlin1234
posted on 20/1/15 at 07:33 PM Reply With Quote
If the “effective date” cannot be determined, it must be assumed to be on or after 1 August 1997.
loggyboy
posted on 20/1/15 at 07:48 PM Reply With Quote
IIRC the IVA won't know if it's a Q so they won't care, they will want it to pass based on age only. Once its registered you can get a Q and go with visible smoke for MOT.
Mistral Motorsport
gremlin1234
posted on 20/1/15 at 07:55 PM Reply With Quote
Originally posted by PioolyBasically am I stuffed? or will I have to register the car as a Q plate as emmissions wont matter then? I really dont want a Q plate but sounds like I might have to. A real shame considering the whole car uses new parts!!! (
even if going for a Q plate, you have to pass emissions at iva. - but not at forthcoming MOT's
I think there are a couple of options,
if you can <prove> the engine was built before end '95 (and its an “Amateur Built” vehicle) then you get a 3.5% co limit and hc 1200
seconadlly, not sure this is viable thou... if you can't prove the engine is that old, then get a cheep old rv8 engine , pass the iva, then change it after.
edit:
when I say <prove> I mean take the engine no, and compare it to production records. may have to ask Gaydon for help
[Edited on 20/1/15 by gremlin1234]
