Author: Subject: Hayabusa won't turn over?
Dopdog
posted on 31/1/15 at 01:40 PM Reply With Quote
OK car has been perfect, went out to the garage to start the car, the starter turns but does not crank the engine. On 1 or 2 attempts it has turned but then the starter just spins again?
any ideas?
I have rocked the car in gear and this has not made any difference?
CRAIGR
Contributor
Posts 2750
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 31/1/15 at 02:48 PM Reply With Quote
Battery nearly flat ?.
Dopdog
posted on 31/1/15 at 03:15 PM Reply With Quote
no fully charged with a booster battery connected.
I took the cover off the starter gear and was able to turn the gear one way and then got it to lock, great! put it all back together and it turned once then just spun on the starter again?
Is there something in the clutch that might not be engaging after it has been stood? will a bump start work or do more damage?
minitici
posted on 31/1/15 at 03:54 PM Reply With Quote
Think you have one of these fitted to your engine
Extreme Billet Starter
Possibly the upper gear's protection sprag clutch or possibly the lower original Hayabusa starter clutch has gone.
[Edited on 31/1/15 by minitici]
Dopdog
posted on 31/1/15 at 04:06 PM Reply With Quote
Yes that is what I have,
I looked at the top gear and it did look OK (whats the sprag bit then?) will have to take the cover off and check the starter clutch by the look of it?
Dopdog
posted on 31/1/15 at 08:13 PM Reply With Quote
OK found out what the spray gear is.
Next question does anyone know how to test either the spray gear or the clutch gear?
danny keenan
posted on 31/1/15 at 08:26 PM Reply With Quote
Hi mate
Give me a call tomorrow I can tell you how to do this.
07779208569
Thanks Danny
Dopdog
posted on 1/2/15 at 02:19 PM Reply With Quote
thank you for all the replies it was the clutch starter all sorted and running.
Thank you Danny for the help on the phone.
