Author: Subject: Westfield XE exhaust manifold
Bingham
posted on 31/1/15 at 05:31 PM Reply With Quote
I'm pondering one of these but heard they were restrictive compared to expensive bespoke ones. Anybody know the diameter and length of the primaries? I wondered if I could have it converted to a 4-2-1 by cutting the collector off and added secondaries.
laptoprob
posted on 1/2/15 at 09:20 AM Reply With Quote
I ran one in my Avon with a 225hp XE build and ran fine but i would say that it was at its limit. how much HP are you pushing through it?
I ended up taking it off in favour of a bespoke Tony Law exhaust which once fitted did allow the engine to rev better nearer the rev limiter.
Only reason i took it off though was because i was in the process of swapping to a 260hp engine so the Westy one had to go.
[Edited on 1/2/15 by laptoprob]
http://www.youtube.com/watch?v=ajlF4nWJtGA
Bingham
posted on 1/2/15 at 12:11 PM Reply With Quote
Pretty standard really, skimmed coscast head, early type forged pistons with slight extra pocketing, Emen Z2 cams,vernier pulleys, Mecatrol 45mm bodies ( Argentinian Jenvey knock offs - about 60% cheaper), megasquirt. Hoping for 190-200 bhp but more importantly nice flat torque curve.
laptoprob
posted on 1/2/15 at 01:17 PM Reply With Quote
The manifold will be fine for that, no problem at all.
Mine was running 12:1 compression pistons and some fairly hot cams.
