Joelove
| posted on 25/2/15 at 12:44 PM |
Reverse spur gear needed
I'm after a reverse spur gear to sandwich between my diff and prop.
It's to make an electric reverse with a golf starter motor.
40inches
| posted on 25/2/15 at 01:18 PM |
Chesterfield 01246 268080
msisleman
posted on 25/2/15 at 02:20 PM |
I have one, unused that is to fit on a Sierra diff, between diff and prop. The hole in the middle is made to fit over the spigot on the Sierra diff,
then it is currently un drilled so you can drill it to suit. Measurements are: 150mm outer diameter, 58mm inner hole diameter. Made from laser cut
stainless steel. Let me know if this is of use?
Joelove
| posted on 25/2/15 at 02:35 PM |
Do you have one for sale or do you manufacture them or is this just for reference? Thanks joe
Joelove
| posted on 25/2/15 at 02:37 PM |
quote: Originally posted by msisleman
Yeh sounds like this could do the job, are the teeth to fit a golf starter? I'll have to check to see if I have enough room in my tunnel to fit
it and I'll pm you
40inches
| posted on 25/2/15 at 04:21 PM |
Got mine from them, I provided the original drawings. I think they have sold a few to people on here since.
Not at all cheap though, but it fits and the tooth pitch is same as the Golf starter.
Joelove
posted on 25/2/15 at 04:29 PM |
Yeh I thought that about price
Thanks for the info
msisleman
| posted on 25/2/15 at 05:26 PM |
it and I'll pm you
My understanding is that the majority of teeth are the same shape on starter pinions and flywheels? I use the same thing with a Brise starter motor. I
think they are all the same or at least close enough for it to still be a satisfactory mesh. I can take a photo and measure teeth if you want?
Joelove
| posted on 25/2/15 at 06:31 PM |
it and I'll pm you
If you could please that would be great mate
msisleman
| posted on 25/2/15 at 07:38 PM |
it and I'll pm you
Teeth are 5mm width at their base, 2mm at tip, and are 6.5mm in height.
Photo should be here:
https://www.dropbox.com/s/y72vspc3fqul1eh/2015-02-25%2019.25.08.jpg?dl=0
Joelove
| posted on 25/2/15 at 07:53 PM |
I'll go measure in a bit mate. Looks like it would fit tho. How much do you want for it?
msisleman
| posted on 25/2/15 at 07:57 PM |
Ok no problem. £45 posted should cover it.
Joelove
| posted on 25/2/15 at 09:03 PM |
Sounds fair to me bud
