<<  1    2  >>
Author: Subject: Brake proportioning valve needed ?
907
posted on 8/3/15 at 05:15 PM Reply With Quote
Hi All
My car failed IVA on uneven braking, front to back and left to right, so this weekend I have given it a bit of a refurb.
We are talking Cortina front discs with M16 callipers, Cortina tandem master cylinder, and Sierra 9" drums on the back.
Haven't touched the M/C as this was originally bought as a recon unit.
I have stripped, cleaned & re-sealed the callipers. I have fitted new 20.6mm (13/16" slave cylinders to the rear.
I have done a vacuum bleed and put 1-1/2 lts of fluid though to flush the system.
My first question is, has anyone passed IVA with this or a similar set up ?
I took the car up the farm track and even on the dusty gravely spots couldn't lock the fronts first. It really dips the
front suspension but still locks the rears first.
My second question is, should I fit a brake proportioning valve, either non adjustable or adjustable ?
If this could be the answer then recommendations please.
My intention is to pay for an unofficial MOT / rolling road brake test before going back for an IVA re-test.
( now who do I know that works in a garage? )
Thanks in anticipation,
Paul G
[Edited on 8/3/15 by 907]
adithorp
posted on 8/3/15 at 05:44 PM Reply With Quote
What size were your previous rear cylinders? You could try smaller ones.
Not sure adjustable proportioning valve is allowed for IVA. The MOT brake test is done in a different (simpler) way to the IVA one but it should give you L/R balance and F/R
http://jpsc.org.uk/forum/
907
posted on 8/3/15 at 06:07 PM Reply With Quote
I took the old ones out first and measured them before ordering new ones.
I did come across bigger ( 22.2mm 7/8" ) ford slaves but nothing smaller.
The 20.6mm are even used on Fiesta's and I dare say their drums are a lot smaller than a Sierra.
I thought I had read on here that adjustable's could be locked (wired, welded, pinned) once set.
Paul G
posted on 8/3/15 at 07:38 PM Reply With Quote
MOT roller tester is absolutely useless for front rear balance.
The availability of smaller bore wheel cylinders depends on type of system you have Girlng or ATE (Teves)
For the Girling system 17.8 mm cylinders were fitted to some mk3 Escorts.
The left right imbalance indicates a problem Cortina front callipers are notorious for seized pistons and the pads seizing in the calliper
SPYDER
posted on 8/3/15 at 07:50 PM Reply With Quote
I'm not sure whether it would make any difference on your setup but are the connections on the master cylinder the right way round? Could there be an inbuilt bias inside the master cylinder that is working against you?
Google images shows some tandem cylinders to have equal diameter chambers whilst others have differing diameters for the two outputs.
907
posted on 8/3/15 at 08:19 PM Reply With Quote
Regarding the MOT rollers I'm just trying to save a 2 hour drive (to Norwich) and a £90 retest fee.
I believe that the re-seal of the callipers and replacing the rear slaves will have solved the right left balance problem.
They push with just thumb pressure now.
It's just front to back now.
Paul G
907
posted on 8/3/15 at 08:26 PM Reply With Quote
I have the connection nearest the foot pedal going to rear brakes.
Connection nearest the front to the front discs. (No crossover of pipes)
I haven't stripped the master cylinder to check diameters.
If I have to add a valve I will have a look.
Paul G
CosKev3
posted on 8/3/15 at 09:22 PM Reply With Quote
The only adjustable bias allowed for IVA is balance bar type pedal boxes,you are not allowed any type of in line adjustable bias device even if you lock it out.
Some Fords have little valves screwed into the mc ports, which are restrictors.
These are allowed as they are not adjustable, got mine off a Fiesta.
CosKev3
posted on 8/3/15 at 09:26 PM Reply With Quote
http://m.ebay.co.uk/itm/331468749935?nav=SEARCH
You can see them in the bottom ports of the pics in that advert.
Have fitted one to my rear line, but I'm running discs all around, it deffo restricts the rear line as I've had someone press the brake as I turned the wheels.
When front locked I went to rear wheel and I could still turn it.
posted on 8/3/15 at 09:32 PM Reply With Quote
Sounds to me you need to refurb the calipers (electrolysis) new pads, new cylinders shoes and drums (electrolysis). And a sierra proportion valve in the back..
Some red or yellow pads may help as well.
[Edited on 8/3/15 by coozer]
CosKev3
posted on 8/3/15 at 09:55 PM Reply With Quote
I thought I read on here sierra valve is no good for iva?
As it only works with the force of the car moving, so on rollers it doesn't do anything?
renetom
posted on 9/3/15 at 08:44 AM Reply With Quote
Hi
"We had the same problem on our Indy failed IVA
The examiner recommended one of these which is an
automatic valve. did the trick and worked fine.
Adjustable valves are strictly no no for iva
Instant fail even if locked.
Good luck.
907
posted on 9/3/15 at 12:19 PM Reply With Quote
Originally posted by renetom
Hi
Good luck.
Where do you find a Rover part nowadays? I've searched but no joy.
Paul G
CosKev3
posted on 9/3/15 at 12:55 PM Reply With Quote
Hi
Good luck.
Paul G
It will do exactly the same job as the Ford ones I've linked too earlier.
posted on 9/3/15 at 01:58 PM Reply With Quote
Hi
Good luck.
Paul G
Not exactly difficult to find with Gogle/Ebay search but pricey unless you can find a scrapper.
As already said Ford Mondeo or Vauxhall Corsa B valves are cheaper and do the same job.
Do an ebay search on FORD MONDEO BRAKE VALVE.
THe Rover 25 and 45 also have valves which are dead easy to get at in the scrappies but because they are double circuit valves the plumbing would not be an easy fit on a live axle car.
JAG
posted on 9/3/15 at 03:40 PM Reply With Quote
Smaller rear drumbrake cylinders will work.
The Girling one's come in 17.8, 19.05, 20.64, 22.2 diameters.
I have M16 front calipers and 8" rear drumbrakes with 22.2mm wheel cylinders.
Your car will work fine with 9" rear drumbrakes but smaller cylinders; either 19.05 or 17.8 would be enough.
Justin
renetom
posted on 9/3/15 at 04:44 PM Reply With Quote
Hi we had 4 pot wilwoods on the front & drums on the rear.
When we went for the re-test the examiner told us to do about 10 laps of the test centre
with our foot on the brake to bed in the new pads
Then watched us whilst we did emergency stop.
Only 2 years ago.
There is another valve which is from an old Range rover that will do
but you will have to put yourself out and go to a breakers.
Good luck
907
posted on 9/3/15 at 04:53 PM Reply With Quote
Having trouble with my internet.
Have found a Mondeo valve but will try Fiesta mk4 17.5 cylinders first.
Paul G
[Edited on 9/3/15 by 907]
JAG
posted on 10/3/15 at 09:28 AM Reply With Quote
Not all valves are the same.
They are supplied with different cut-off pressures.
Justin
adithorp
posted on 10/3/15 at 10:25 AM Reply With Quote
Paul G
That should do it.
Slight thread drift... Has anyone seen a stepped master cylinder like SPYDER mentions? In all my years in the trade I've yet to come across one.
SPYDER
posted on 10/3/15 at 10:46 AM Reply With Quote
I saw these images ...
They look like different chamber diameters. The top one is from a BMW site.
The bottom one has the chambers labelled up for a diagonally split system though, so the pressures must be the same. I'm confused.
Edit: Looking at it again it isn't a one piece piston rod with two different diameters. The pedal will generate pressure in the first chamber which will create, via the second piston, the same pressure in the second chamber.
As you were.
[Edited on 10/3/15 by SPYDER]
matty h
posted on 10/3/15 at 11:12 AM Reply With Quote
PM sent regarding valves.
Matty
posted on 10/3/15 at 11:27 AM Reply With Quote
Paul G
That should do it.
I
Istr Vauxhall/Opel used them on some RWD models, Ford never used them as Ford like most manufacturers always used a diagonal split.
posted on 10/3/15 at 11:29 AM Reply With Quote
Paul G
That should do it.
I
907
posted on 10/3/15 at 01:29 PM Reply With Quote
Matty
Yes please, But my internet won't let me reply to your u2u
Paul G
edit
Just tried from my phone.
Send a text to 07779 561613
[Edited on 10/3/15 by 907]
<<  1    2  >>
