Author: Subject: R1 bits please
Wes
posted on 13/3/15 at 07:54 PM Reply With Quote
R1 bits please
Hi all,
I'm building a Indy R1 and need some parts from a 2002-06 5VY ASAP if poss. I'm looking for,
Clock loom or Headlight loom
Exup valve
Let me know if you have anything please.
Wes
07515934136.
motorcycle_mayhem
posted on 13/3/15 at 08:21 PM Reply With Quote
You have a PM
adithorp
posted on 13/3/15 at 09:17 PM Reply With Quote
The 5vy is 04-06. 02-3 is different
Why do you need an EXUP? It can be replaced with a littleelectronic box of tricks and save a load of weight and whirring. Search on here for Exup widget and you should find instructions. Mines been on for almost 7 years now with no issues.
http://jpsc.org.uk/forum/
Wes
posted on 13/3/15 at 11:31 PM Reply With Quote
Sorry yeah just double checked and it's 04-06.
Dig innately interested in a replacement if I can get hold of one but ice read that a few of them don't work properly as a replacement?
adithorp
posted on 14/3/15 at 12:15 AM Reply With Quote
I made my own using the info in THIS THREAD
I rubbish at that sort of stuff generally but managed it and did an idiots guide in HERE
I have heard of some of the ebay ones not working. There are also reports of engines blowing with neither EXUP or widget so def do one or the other.
renetom
posted on 14/3/15 at 07:49 AM Reply With Quote
Hi
Tried one of those electronic widgets to replace exup
it failed miserably throwing up all kinds of faults.
Bought an exup motor took off the pulley & cut down the shaft
Just put it in the engine bay, its virtually silent
weigh's almost nothing, and .worked perfectly
Good luck
bigfoot4616
posted on 14/3/15 at 06:27 PM Reply With Quote
i made a widget and i assume it works, as i don't have the clocks is there any way of knowing if it stopped working?
hobbsy
posted on 14/3/15 at 08:24 PM Reply With Quote
Earlier engine but no issues with the widget either
Davey D
posted on 14/3/15 at 08:36 PM Reply With Quote
I made one myself with plans found on this forum. It's been on the car from day one. 6 years on the road and track it has never been a problem
