Author: Subject: Propshaft for sale
stevegough
posted on 21/3/15 at 08:21 PM Reply With Quote
Propshaft for sale
Hello everybody! I'm still alive, though its over a year since my last post.
Only visiting today because I've got to clear out the garage for the house move.
I bought a Kit car prop of someone on here about 5 years ago I think.
It didn't fit my Luego, so I ended up getting one made... expensive mistake really!
Anyway, the prop is from a Ford type 9 gearbox ( ? 23 splines I think ? )
But it doesn't connect to a Sierra Diff - its too small.
I believe it's tail end fits an 'English Axle'.
Measurements:
Gearbox end Outside diam = 35mm or 1 3/8" - inside, the splined shaft would measure 25mm (without the splines) - definitely type 9.
Length - tip to tip - measured as shown in the photo with everything held straight. = 750mm
With the drive end fully inserted up to the hilt, its effective length is = 658mm
There is 92mm insertable. I'm not sure what the min recomended is but I would imagine about 30mm or so.
Rear plate has a 1mm proud of the main plate collar ring inside of the bolt holes.
Rear plate is 82mm dia.
PCD (centre of bolt hole to centre of bolt hole is what I mean - pretty sure they call this PCD!)
The centre collar is 57mm dia.
I would like £65 for this posted, and I'll be putting it on eBay later tonight or tomorrow. (I am in Blackpool if someone is collecting).
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Bolt
posted on 21/3/15 at 10:47 PM Reply With Quote
Hi mate,
I will take it! Will contact via u2u.
Cheers, Simon
stevegough
posted on 22/3/15 at 07:39 AM Reply With Quote
U2U replied to, Simon.
Luego Locost C20XE.
Bolt
posted on 22/3/15 at 10:34 AM Reply With Quote
Cheers mate; money sent via PayPal.
stevegough
posted on 22/3/15 at 11:29 AM Reply With Quote
Thanks! Payment received, and propshaft now sold.
Luego Locost C20XE.
Bolt
posted on 25/3/15 at 09:07 AM Reply With Quote
Must say, brilliant packaging, quick delivery and great correspondence. Also to my surprise it fits in my build perfectly!
Thanks for this.
Cheers, Simon
stevegough
posted on 25/3/15 at 05:47 PM Reply With Quote
Fantastic! Glad to hear you got it safely, and that its such a good fit.
Result! Good luck with rest of the build!
Luego Locost C20XE.
