Author: Subject: Joining Electrical Wires
ash_hammond
posted on 24/3/15 at 04:49 PM Reply With Quote
My loom has three main power feeds into the fusebox.
Ideally for neatness I would like to join all this wires together and then run a single heavy duty lead to the battery though a grommet in the scuttle to the positive terminal.
Is soldering all these wires together and then heat shrinking them a sensible idea or is that a connector that will do this job?
Cheers.
.: www.mac1motorsports.co.uk | www.m1moc.com :.
JeffHs
posted on 24/3/15 at 04:54 PM Reply With Quote
I know some will argue that soldering is not a great idea, but when I made my loom from a Mk2 Escort one, I found several soldered connections made by Ford, so I followed suit and have had no problems since!
posted on 24/3/15 at 07:37 PM Reply With Quote
Why not just thread the 3 wires through a single shrink wrap to join at a single Midi fuse holder and then a single heavier wire to the battery.
This would be better than having a completely unfused feed going through a metal bulkhead.
If you want a soldered joint that as reliable you have to make a mechanical splice that is intertwine the wires properly before you solder.
Chris_Xtreme
posted on 24/3/15 at 07:52 PM Reply With Quote
I did just what you describe, one large wire through the bulkhead - (not fused at this point) into a fust up under the passenger footwell, then large wire into a large 'butt connector' and the three wires in the other side of it.. screw them up, heat shield over the top and done. my local car shop had them, but I can't find an example quickly online!
ash_hammond
posted on 24/3/15 at 08:00 PM Reply With Quote
Thanks for the ideas.
I have just found this ebay item
What are peoples thoughts? It does come with a cover but it does seem a little exposed to me given every metal surface is earth.
matty h
posted on 24/3/15 at 08:15 PM Reply With Quote
Few here I have used the two way junction box before was told by a vehicle wiring firm to use this instead of any of butt connectors.
http://www.vehicle-wiring-products.eu/section.php/97/1/terminals-connectors
Matty
Chris_Xtreme
posted on 24/3/15 at 08:26 PM Reply With Quote
this is what I used:
http://www.vehicle-wiring-products.eu/product.php/561/butt-connector-screw-type/32ffe1153c4f72fd5e7672f47da5a1a3
or screwfix do crimp ones
http://www.screwfix.com/p/10mm-butt-connector-pack-10/58923
(thanks for the pointer to VWP !)
[Edited on 24/3/15 by Chris_Xtreme]
ash_hammond
posted on 24/3/15 at 08:27 PM Reply With Quote
Matty
Thanks. I think i will order one of those.
SteveWalker
posted on 24/3/15 at 09:38 PM Reply With Quote
I'd connect the three to one as originally suggested, but use a battery connector with an integral fuseholder to feed the single larger wire, so you have no unfused section.
In my case, I didn't have a fused battery connector available and simply fitted an inline fuseholder (AGU / 5AG) and 60A fuse from Maplin into the feed, very close to the battery.
renetom
posted on 25/3/15 at 08:10 AM Reply With Quote
Hi
Solder & heatshrink by far the best
trouble free connection.
Looks neater than crimps or connectors.
Good luck
Irony
posted on 25/3/15 at 08:59 AM Reply With Quote
I have two plastic junction boxes under my dash. One for permanent live and one for earth. In the junction box is a bus bar that is secured inside. If I was wiring the car again I would have one for switched live as well.
SPYDER
posted on 25/3/15 at 09:43 AM Reply With Quote
Solder and heatshrink for me. The OEM loom that came with my engine (Toyota) is full of soldered joints.
Having a fuse near the feed point is a good idea though.
loggyboy
posted on 25/3/15 at 09:49 AM Reply With Quote
Done well both crimp and solder are fine. Both are OE ways of doing things. What i've tend to notice is solder is only used to join multiple wires in areas of no movement in the loom, ie where loom is well wrapped and supported. Any connectors or similar will always be crimped as even a good soldered joint will become brittle.
Mistral Motorsport
coyoteboy
posted on 25/3/15 at 01:53 PM Reply With Quote
Many say don't solder. I prefer soldering for a better electrical connection, but it does require proper stress relief on the joint (multiple layers of heatshrink properly shrunk extending 25mm either side works nicely). I think the "problem" is the solder creates a hard spot that causes localised stress raising and fatigue failure under vibration. The heatshrink limits this by spreading the load over an area. Personally I find no-one can reliably crimp anything without wire damage and it then is an open corrosion point too, which to my mind is worse.
spiderman
posted on 25/3/15 at 10:58 PM Reply With Quote
You do need some decent ratchet wire crimpers, not those cheap pliers type made from flat steel. I use both crimp and soldered joints and have in the past soldered a crimped joint, especially if I have multiple cores going into a single core the other side. If you want to keep environment out of crimped joint put heat shrink insulation over it, 3:1 or 4:1 shrink ratio and get the adhesive lined stuff, not cheap but excellent and fit for purpose. We all know it can be a nightmare tracing a corrode or badly made connection in a wrapped wiring loom. I often use convoluted conduit to ron my wires in, so much easier to replace a faulty conductor or to add more for extra added accessories.
If I have to use those blue/yellow and red insulated crimp connectors, I slide some heatshrink, adhesive lined, over the conductor first then crimp cut off the insulation with a dremmel flow some solder into the crimp and then slide heatshrink over the joint, wait for it to cool after soldering, then use a decent heat gun, not a lighter As you can gather I hate those insulated crimp connectors, I have wasted too much of my life trying to source a badly crimped one, plus they look crap and unprofessional. Never ever use those scotchlock connectors that cut through the insulation when you want to add a condutor to an existing one, often used by baboons fitting tow bar electrics.
these abominations,
you deserve everything you get if you do
Spider
coyoteboy
posted on 25/3/15 at 11:26 PM Reply With Quote
Yeah but even decent crimp tools require careful adjustment to the correct sizing and checks on pull-out strength (we do high reliability crimping here at work, with ESA qualified technicians, and even they take a few attempts!).
Agree, anyone using cut'n'shut connectors is asking for a nightmare. Definitely worth environmentally sealing the joint wherever physically possible to prevent the old black rot!
