New Topic New Reply
Author: Subject: indy mushroom inserts
ASH3
posted on 30/4/15 at 06:12 PM Reply With Quote
Just a quick one should the front top ball joint when the insert is in the hub be at the front or to the rear had a brain freeze...
jacko
posted on 30/4/15 at 06:15 PM Reply With Quote
Front
Jacko
ASH3
posted on 30/4/15 at 06:19 PM Reply With Quote
Cool got them to the front after having everything off for repaint it's all back together and now skips n jumps on the slightest bump must be tracking issue. ..
whitestu
posted on 1/5/15 at 09:02 AM Reply With Quote
Sounds more like bump steer to me.
ASH3
posted on 1/5/15 at 09:24 AM Reply With Quote
How do I sort bump steer I've only tonight to get it right for Stoneleigh tomorrow. ....panic panic
alfas
posted on 1/5/15 at 10:08 AM Reply With Quote
if everything was fine b4 you disassembled the front for repaint, basically the front settings are wrong
track, camber, castor (if adjustable)
so you should visit your nearest wheel alignment centre to get this corrected
ASH3
posted on 2/5/15 at 03:57 PM Reply With Quote
With a bit of last minute tweeking I'm sat at Stoneleigh how cool..
whitestu
posted on 2/5/15 at 04:43 PM Reply With Quote
Well done!
New Topic New Reply
