New Topic New Reply
Author: Subject: Which 7 style kit for first build??
Autoflock Motorsport
posted on 6/5/15 at 12:16 PM Reply With Quote
just after some comments and opinions, a friend and myself are contemplating buying 2 kits and building them in tandum, to be used a fast road/track cars.
Can anyone offers some comments as to a good kit for a first time build please?
We would be looking at a car engine, ideally are dry sumped zetec turbo'd probably using a c/cooler depending on space
Kind regards
Raj
http://www.locostbuilders.co.uk/forum/23/viewthread.php?tid=183445
Ugg10
posted on 6/5/15 at 12:24 PM Reply With Quote
If you are going down that style of engine/car and also being your first build(s) then I would suggest looking at an MX5 single donor kit, many of the manufacturers now offer this option (MNR, Westfield, Roadrunner, GBS, Locost etc.). If you pick up a mk2 MX5 1800 with a torsen diff you will have a very good car to start off (and IVA) with and there are several turbo or supercharger kits/builds around for that engine. This would not be that much less powerful than a turbo'd zetec and much easier to build and get through IVA.
Just my 2p worth to kick things off.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
baz-R
posted on 6/5/15 at 12:49 PM Reply With Quote
it would depend on how techinical you are and what your fabricating skills are
personaly i would try and seek out somthing that fits your skillsets and budget and offers a comprehensive kit of parts
other option is to find a unfinished kit you could finish yourself
Thanks very much for that, good food for thought, only reason im keen on the zetec is within my circle of friends and their comapnies they specialise in building/installing and mapping them so support and custom parts are very easy for me to get hold of as opposed to starting a fresh with a new brand of engine. (and im a ford fan, shoot me now)
Been looking at the ford based GBS kit which seems to be a bargain, if not a little too cheap which alarms me a bit simply because I know nothing about the latest 7 kits. I do love the MNR vortx inboard but not sure if thats a bit over kill for what im after, certainly looks the business.
Kind regards
Raj
luke2152
posted on 6/5/15 at 01:41 PM Reply With Quote
Its cheap because its basic. That's not a bad thing but you will need to pay extra for things like engine mounts, lights, dash etc which some other kit makers include
Slimy38
Do a bit of work as to what is actually in a 'kit', as it's not standard across all manufacturers. From memory, MNR are very good at including parts that other manufacturers might consider optional. I have a feeling they have one kit on their website that is pretty much 'add engine', and that's it!
GBS do cheaper kits, there's nothing wrong with that but you might find you have to buy more bits, and they may not be as much of a saving.
Alternatively, have a look at Talon Motorsport to deliberately start with the basics (chassis + wishbones), then build the rest up from a donor car or off the shelf. It's a bit more hard work to collect things together (especially two of everything), but at least there won't be any surprises.
edit: Luke beat me to it!
[Edited on 6/5/15 by Slimy38]
pewe
posted on 6/5/15 at 02:52 PM Reply With Quote
NTDWM but this one on here strikes me as a bargain if you don't want to start with a pile of steel and end up with a car - see RichB's post "Unfinished Luego Velocity Xt for sale".
Problem is most builds from scratch take far longer than anyone anticipates.
I think the longest on here is 17 years but 3 or 4 years isn't unusual.
So you need to weigh the time factor against how soon you want to be driving it.
The spec/price on this one seems pretty good and you could easily swap the Toyota for Ford power if that's a priority.
HTH.
Cheers, Pewe10
whitestu
posted on 6/5/15 at 07:22 PM Reply With Quote
HTH.
Cheers, Pewe10
I agree
I'd have bought that if it had come up when I was building my MK.
My build took a year with a bought chassis which I thought was quite good.
Stu
posted on 6/5/15 at 08:56 PM Reply With Quote
not sure I approve of that post recommending the luego
I am now counting pennies :-( lol cheers
Looks like a great base, need to do some research and thinking, which even kit I got for it has to be boosted
Kind regards
Raj
joneh
posted on 7/5/15 at 07:07 AM Reply With Quote
A part built project is a great way of learning, as you find that you take the whole thing to bits for peace of mind, then reassemble!
Part built projects can take even longer than a new kit...
posted on 7/5/15 at 07:22 AM Reply With Quote
cheers for the feedback, the actual mechanical assembly doesnt worry me, ive built a few cars but they were CARS not kits, I heard lots of horror stories about parts not fitting etc so was thinking which is the best kit v price for a straight forward build, ive done a lot of modifications to my current kitcar which I bought already built which is the main reason I want to start from scratch with my own stamp on it so to speak.
But that luego :-( FML
that is so tempting and I really like the shape. I was thinking the MNR but if im honest I just dont like the look of it, but besides the looks it appears to have the best bits ive found so far.
Kind regards
Raj
bombero
posted on 21/5/15 at 06:32 AM Reply With Quote
A little known company based in East Lothian called the Scottish Kitcar Centre (SKC) build the RaptorR and RaptorRR. These are based on the MK chassis and use many of their parts but are bespoke to SKC. He's supplied a number of kits to date but you'd be best to speak to Andy (owner) directly on: 01620 880763. Don't be put off by his location as he, like other suppliers, can supply kits nationally and his customer support is very good! His background is in performance engine building and he can provide you with a lot of support in regards to the zetec turbo in a seven. Tell him Rab sent you.
CosKev3
posted on 21/5/15 at 07:17 AM Reply With Quote
The best quality and easiest build would be a Westfield, they are not a lot more expensive than other kits either tbh.
The quality of fibreglass panels is massively better than other manufacturers
bombero
posted on 21/5/15 at 07:35 AM Reply With Quote
I'd tend to agree and not just because I've got a Westfield but having studied many other kits up close, the panels are one area that Westfield stand our for sure!
posted on 21/5/15 at 07:36 AM Reply With Quote
currently in talks with getting 2 818r kits shipped over from Boston MA. The factory Five kit seems really special and some of the online footage on track is breathtaking.
Kind regards
Raj
bombero
posted on 21/5/15 at 07:54 AM Reply With Quote
Certainly not a seven and has a hybrid mixed look about it of Chrysler/Porsche/Nissan..
posted on 21/5/15 at 08:00 AM Reply With Quote
yes i know mate, a friend pointed it out to me and i sort of fell in love instantly, its got a lot of lotus/s2000 in it. But it certainly stands out and looks very good quality. FFR seem to have a great reputation from what I have read.
Kind regards
Raj
bombero
posted on 21/5/15 at 09:27 AM Reply With Quote
I certainly wish you all the best in the build and look forward to watching a build diary!
velocitykendal
posted on 21/5/15 at 11:50 AM Reply With Quote
Following on from Ugg10's suggestion of an MX5 SDV I noticed this part-built SR2 up for sale on eBay:
http://www.ebay.co.uk/itm/231556939326
(NTDWM)
Personally if going MX5 I'd seriously think about forced induction options such as the supercharger kit mentioned in the ad, they're pretty gutless in N/A form.
posted on 21/5/15 at 12:45 PM Reply With Quote
I would recommend the MNR as in very easy to build.
I built mine in around 3 months, that's the amount of time I spent on it not the time it lay idle in the garage for months while I was working.
2 of you in random is the perfect balance of enthusiasm and helping each other out.
Chris and Mark at MNR are very helpful with problems and the new fibreglass body is very good.
I was well on my way to turbocharging the st170 engine in mine and had even gone as far as mounting the rx7 intercooler in the nose. Plenty of room for a turbo engine with fmic.
Good luck!
New Topic New Reply
