Author: Subject: Windscreens to Fit MK Scuttle
Bumble
posted on 6/5/15 at 03:18 PM Reply With Quote
Other than MK themselves, what full screens have others used that fit the MK scuttle??
Considering fitting one to mine although I have full cage - has this been done by anyone before?
Thanks,
Matt
INDY BIRD
posted on 6/5/15 at 03:25 PM Reply With Quote
caterham one fits,
like this
Bumble
posted on 6/5/15 at 03:44 PM Reply With Quote
Hi thanks for the reply (lovely looking car) but the Caterham one is even more expensive than MK!!!!
madteg
posted on 6/5/15 at 04:06 PM Reply With Quote
I made a frame, fitted to the car and then got the glass cut to size. I brought the frame of GBS and the glass cost £30.00 ( laminated)
Bumble
posted on 6/5/15 at 04:08 PM Reply With Quote
Does the GBS one fit or did you have to modify?
madteg
posted on 6/5/15 at 04:58 PM Reply With Quote
You buy the top rail that can be opened or closed and bend the bottom rail to suit the scuttle.
INDY BIRD
posted on 6/5/15 at 05:01 PM Reply With Quote
i know where you can get one 2nd hand with a set of new uprights and new glass for it,
If any good drop me a u2u,
thanks
sean
40inches
posted on 6/5/15 at 05:06 PM Reply With Quote
That's what I did, laminated glass is really cheap from window places, make a 3mm MDF template.
whitestu
posted on 6/5/15 at 05:15 PM Reply With Quote
I bought a Caterham one with cracked glass and had a piece of 4mm laminate cut for about £35 iirc.
It fits really well.
Stu
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 6/5/15 at 06:26 PM Reply With Quote
That's my old car !!
I've just PM'd you.
I have a couple of Caterham windscreens with new glass.
Drop me a line if you're interested.
