mad-butcher
posted on 1/12/04 at 02:18 PM |
position of front flexis
any body be kind enough to post the dimensions for the mounting of the front flexis i'm using standard MK flexis
many thanks
tony
geoffe
posted on 1/12/04 at 06:04 PM |
Front brake flexis
This is how we ran ours. Photo shows the braket in position held with a clamp. Brackets are steel strip rivetted to the chassis. Hope this helps.
Geoff.
![](http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=14th%20November%20-%20Rear%20Bulkhead%20&%20Wheels%20fitted%2010%20(cro
p).JPG)
geoffe
posted on 1/12/04 at 06:05 PM |
Damn!! no photo
ReMan
posted on 1/12/04 at 07:31 PM |
""front brake pipes on indy
mounting these have been driving me crazy.. trying to make sure they clear everthing so i emailed MK and here are the measurements .
around 200mm down from top rail and around 75-80mm in from rear of top wishbone mounting leg (sort of inline with bolt for bottom wishbone when
looking from above........ should have done that months ago instead of titting around. hope it saves some-one else the hassle i've had.
I used this advice copied from a posting somewhere, It could help if you can decipher it!
also used pictures of the various postings on the forum help
Col
[Edited on 1/12/04 by ReMan]
bob
posted on 1/12/04 at 08:01 PM |
I found this hard too,it turned out ok in the end and doesnt rub anywhere.
I bet everyone has them in a different possition though.
![](/galpreviews/a159276-MK Indy build pics 075.jpg) ![Rescued attachment MK Indy build pics 075.jpg](/gallery/a159276-MK Indy build pics 075.jpg) Rescued attachment MK Indy build pics 075.jpg
bob
posted on 1/12/04 at 08:03 PM |
and from the inside
![](/galpreviews/a159278-MK Indy build pics 073.jpg) ![Rescued attachment MK Indy build pics 073.jpg](/gallery/a159278-MK Indy build pics 073.jpg) Rescued attachment MK Indy build pics 073.jpg
CairB
posted on 2/12/04 at 12:17 AM |
By eck Bob that looks clean.
Taken a while ago I reckon.
BTW you win your bet - I attached mine to the side of the equivilent of Rons "FUx" members.
Colin
