Author: Subject: South east exhaust fabricators?
bassett
posted on 8/6/15 at 12:32 PM Reply With Quote
Hi, our MNR with R1 bike engine is always a bit of a challenge when it comes to yearly MOT and emissions. Does anyone have advice for someone who could build and test a rear silencer and cat that would make our lives a bit easier? Ive heard a bit about vortex exhausts from the wheeler dealers show and there seem to be a few suppliers near croydon so are they worth a shot?
Adam
Chris_Xtreme
posted on 8/6/15 at 01:31 PM Reply With Quote
a few years (4ish) back I had the can replaced on my pinto powered exhaust -
http://www.powerspeed.co.uk/exhausts.html
they did a great job fitting the can, raising the level of it and bending the pipe etc.
can't comment on now or if they could sort out emissions - that sounds like the ecu needs a tweak to me.
should have said they are in ashford, kent.
[Edited on 8/6/15 by Chris_Xtreme]
motorcycle_mayhem
posted on 8/6/15 at 02:32 PM Reply With Quote
Simpson Exhausts would certainly be able to make the system....
I've used them a few times, no issues.
matt5964
posted on 8/6/15 at 03:08 PM Reply With Quote
Plus one for simpson, Matt and the team are ace.
Luego velocity XT 2.0ltr 221.3bhp 178.9lbft
Ugg10
posted on 8/6/15 at 03:45 PM Reply With Quote
The exhaust design in general will not affect emission hugely on it's own unless you add a CAT or the CAT is not functioning and needs replacing. The exhaust can affect noise level but not sure this is an MOT requirement. If you are struggling to pass emission then it is probably a fueling issue and the ECU needs tuning or the lambda sensor is faulty or you have an inlet air leak. That said, I guess it could also be a cracked exhaust pipe but you would easily be able to sense this (and hear it?).
Just a few thoughts, not worth spending loads on a bespoke new exhaust system to rectify an emissions fault when the problem is elsewhere in the system. Get the basics right first and then tweak later.
Just my 2p's worth.
[Edited on 8/6/15 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
bassett
posted on 8/6/15 at 06:04 PM Reply With Quote
Thanks for responses so far. I will look into the recommendations.
Just to add I'm pretty sure fueling is ok as it had both a power and optimised air fuel setup for idle at PDQ and also had a few other service bits done. It gets really close on emissions but the cat is an eBay special and the rear can has some blowing so I'd like to get both sorted by a specialist who can recommend something that will help and saving a few dB's for trackday would be nice.
[Edited on 8/6/15 by bassett]
