Author: Subject: 7.5 to 7 diff spacers
craig5
posted on 26/6/15 at 07:33 PM Reply With Quote
had right pig of a day today removing the diff out of my STM only to try fit my new 7" 3.6 and as u guessed even though I was told would be straight fit I need spacers anyone know where I can get them from płease and sizes I will need
snapper
posted on 26/6/15 at 07:39 PM Reply With Quote
The 7 ½" uses individual bolts
7" uses a through bolt
So you may need a long bolt then simple washers will suffice
Or a tube cut to length
I eat to survive
I drink to forget
CosKev3
posted on 26/6/15 at 08:02 PM Reply With Quote
Also best check your drive shafts, 7 inch use 100mm lobros, most 7.5inch diffs have 108mm lobros.
craig5
posted on 26/6/15 at 08:40 PM Reply With Quote
Lobros you mean the end plates that connect to the drive shafts?
CosKev3
posted on 26/6/15 at 09:31 PM Reply With Quote
Yeah
craig5
posted on 26/6/15 at 09:42 PM Reply With Quote
Is the 108 the total plate diameter? Or distance between holes
loggyboy
posted on 26/6/15 at 11:01 PM Reply With Quote
Distance between holes IIRC
Mistral Motorsport
craig5
posted on 27/6/15 at 08:15 AM Reply With Quote
are you sure as measured and it appears the plate is 100mm
daniel mason
posted on 27/6/15 at 08:30 AM Reply With Quote
Craig. Spend the morning reading this.it should help a lot
http://www.super7thheaven.co.uk/components/sierra_rear_differential/
gaz_gaz
posted on 27/6/15 at 08:35 AM Reply With Quote
You are measuring the plate.
100mm lobro has hole pcd of about 84mm from memory.
CosKev3
posted on 27/6/15 at 09:27 AM Reply With Quote
http://www.gwr-fasteners.co.uk/m10-x-20mm-od-spacers---standoff-collar---stainless-steel-21282-p.asp
so have you landed lucky and got the correct 100mm lobros to fit onto a 7 inch diff?
Something like the above will do for spacers if your worried about using washers.
