Author: Subject: ETB Dash Gear Indicator playing up
Autoflock Motorsport
posted on 8/7/15 at 12:24 PM Reply With Quote
just a quick one, on my last outing I noticed my gear indicator on my digidash has started playing up and looks like it is getting confused.
Can anyone advise where to start looking to diagnose the problem
Raj
Kind regards
Raj
http://www.locostbuilders.co.uk/forum/23/viewthread.php?tid=183445
loggyboy
posted on 8/7/15 at 12:47 PM Reply With Quote
IIRC its linked to revs and speed and uses the two to calculate gear, if you have changed anything (gear ratios, speed sensor etc) then this may be cause.
Mistral Motorsport
HappyFather
posted on 8/7/15 at 07:13 PM Reply With Quote
If you haven't changed anything, look for an earth failing. I had several issues with my Digidash regarding revs and selected gear and it was all down to earth wires.
amalyos
posted on 8/7/15 at 08:30 PM Reply With Quote
Normally a speed sensor problem, maybe the positioning of it has moved or you've lost a magnet.
http://stevembuild.blogspot.com
karlak
posted on 8/7/15 at 08:31 PM Reply With Quote
Check the ETB indicated road speed against a GPS on a phone or similar ?
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
