spegru
posted on 18/7/15 at 04:03 PM |
Focus Zetec Temperature sensor
Does anyone know where it should be on a 2.0 black top engine?
The thermostat housing doesn't have any electrical connections or empty holes
[Edited on 18/7/15 by spegru]
posted on 18/7/15 at 04:15 PM |
Its normally on top of the thermo housing...
Got a pic of yours??
I'll go take a photo of mine....
big_wasa
posted on 18/7/15 at 05:10 PM |
Focus is in the head. Near / under cylinder 1 on the inlet side.
posted on 18/7/15 at 05:16 PM |
Here it is....
big_wasa
posted on 18/7/15 at 05:48 PM |
They moved it to the head in the focus
[Edited on 18/7/15 by big_wasa]
posted on 18/7/15 at 06:46 PM |
Hmm, does the focus not use the same thermo block?
big_wasa
posted on 18/7/15 at 06:56 PM |
Yes, well no.
Yes it's the Same sort of thing but the bosses are blank. Dash gets its info from the scp bus.
No they changed the design a little and made them cheaper. They distort and leak.
Earlier the better for quality and you can add sensors for the dash in the spare hole.
[Edited on 20/7/15 by big_wasa]
spegru
posted on 19/7/15 at 08:04 AM |
Brilliant. Thanks guys. For a moment I thought there has been a confusion with the cam sensor, but no there it us on the right of the picture and
sure enough mine has one hidden away under the plenum. On my last project I had two sensors in the the thermostat housing - one for the ecu and one
for the dash. Luckily the housing had enough holes. This one doesn't have any so I guess I'll also have to find another housing with at
least one hole if I want a dash gauge as I don't think you can attach two things to the same sensor as it would distort the readings. I might
have one lying around somewhere. ....
Paul Turner
posted on 20/7/15 at 03:21 PM |
The solution is simple, use a Silvertop housing and throw the Blacktop housing away (actually put it on E-Bay, mine fetched £55. The Silvertop housing
allows you to fit ECU and gauge sensors that match your ECU and gauge.
The hole in the head where the Blacktop sensor fits is not drilled into a gallery so nothing to blank off.
