Author: Subject: Brakes!! Can I use abs, is it ok and ok for iva?
villagehoppa
posted on 23/7/15 at 12:00 PM Reply With Quote
Hi All, I'm working on a project which basically re-bodies a Ford Focus Mk2 on to a spaceframe chassis, my question is, when it comes to the brakes, can I carry over the whole brake assembly including the abs? I didn't know where the IVA stood on such things? As the vehicle will be substantially lighter than the donor would there be any problems too? I'm guessing that the brakes would lock up easier so would there be any way of adjusting them or better just going with an aftermarket set up? I want to use as much of the donor to keep costs down so would ideally like to go with the donor set up. Any inputs would be most appreciated. Thanks in advance..
Daf
posted on 23/7/15 at 12:33 PM Reply With Quote
I can't see a problem with using it, the ABS senses when a wheel locks up (stops rotating) so weight shouldnt make any difference. The Focus ABS would work equally well with 5 fat people in it or one skinny person. I'd be tempted to stick with a braking system a manufacturer will have spent millions on developing as aposed to anything else. This is just my opinion though - I'm sure someone will be along to prove me wrong!
loggyboy
posted on 23/7/15 at 12:53 PM Reply With Quote
Depends on the original system, for example the ABS on my clio also dicates brake balance, so weight changes may have a negative effect.
Do you really want it?
Mistral Motorsport
coyoteboy
posted on 23/7/15 at 12:56 PM Reply With Quote
Depends how advanced the system is in the donor. Even as far back as the early 90s cars were using inertial sensors to identify acceleration rates and adapt their output based on that - the wheel speed sensing is only part of it. It's hard to know what the effect would be without knowing the details of the system of course and it might simply be the case that the parameters of the control are slightly different for a lighter car as the correction happens faster etc. Certainly plenty of ABS/stabilty systems detect weight levels in the car and set brake biasing and change triggers based on things like rate of decel with rate of wheel speed change etc. That said, none of that affects whether the IVA allows it etc, which I think it does off the top of my head.
[Edited on 23/7/15 by coyoteboy]
prawnabie
posted on 23/7/15 at 01:40 PM Reply With Quote
That would be EBD, best to avoid cars using that if you are puting the system into something else.
Kdempsie
posted on 23/7/15 at 05:59 PM Reply With Quote
I'd need to double check but I think ABS is specifically forbidden in the IVA manual.
robertst
posted on 23/7/15 at 06:15 PM Reply With Quote
Nope, its allowed:
But i guess more testing will be necessary, so one more thing for them to fail
Tom
turbodisplay
posted on 23/7/15 at 07:37 PM Reply With Quote
Main issue with ABS is unintentional Ice mode activation, where the lower mass makes the ABS think the car is on Ice so gives massively reduced braking.
Darren
Kdempsie
posted on 23/7/15 at 08:05 PM Reply With Quote
Oops, my bad. Must have been thinking about something else.
Bluemoon
posted on 23/7/15 at 08:44 PM Reply With Quote
other snag may be at mot time i.e. are you allowed to remove the abs system if it has one at iva, not sure what they cary-over to the v5. you might be locked into keeping abs?
talkingcars
posted on 23/7/15 at 09:34 PM Reply With Quote
It is possible to remove it from a regular car but you have to remove all trace, even the light on the dash.
talkingcars
posted on 23/7/15 at 09:35 PM Reply With Quote
And these sensors are normally hidden in the ABS ECU.
villagehoppa
posted on 24/7/15 at 06:41 AM Reply With Quote
Thanks all , great info as always... Brakes are usually vehicles specific I would have thought, it is going to need a bit more research but thanks you for all of you reply's, there is some great stuff there to think about. I don'y suppose anyone knows any 'Ford Brake Specialists' who would know the inner beatings of a 'brake system' heart!!?? Thanks again... J
snapper
posted on 24/7/15 at 08:22 AM Reply With Quote
I do but in all honesty it's like asking a Professor of Quantum mechanics to explain it in simple terms.
The little I do understand is that today's systems are integral with the ECU in that wheel rotation is just a single part of the complex vehicle dynamics, things like lateral G, friction sheer, yaw etc all come in to play, at this stage in the conversation I said "well put it in simple terms" he said "I have" "God how much more simple do you need?"
Gulp
I eat to survive
I drink to forget
DW100
posted on 24/7/15 at 09:57 AM Reply With Quote
The MkII focus uses at least 4 different types of Teves abs pump, most of which have Traction Control System and Electronic Stability Control. This will have been tuned to the exact dynamics of a Focus. It will use info from multiple sensors from multiple control units with info conveyed across the CAN network. Mounting of things like Yaw sensors and G sensors need to be precise in order to give the correct info and the likely vibration from a kit built car could well confuse the system leading to very unpredictable behaviour.
Not saying it can't be done but....... probably beyond the scope of an amateur designer.
villagehoppa
posted on 24/7/15 at 12:41 PM Reply With Quote
Ah I see, very well put. I might have to think of a much simpler way then if that is the case. I don't want anything fancy, just something good and reliable to stop me using as much carryover parts as possible. Maybe I can scrub the abs part and stick to a servo from an earlier models maybe? I'll have a think, thanks again... J Does anyone do a servo assist kit?...
SteveWalker
posted on 24/7/15 at 01:28 PM Reply With Quote
All the fancy bits (traction controls, stability control, etc.) are optional extras aren't they? That should mean that a Ford dealer should be able to disable them. I don't know whether the basic ABS would still be okay for a much lighter car or not, but it's more likely with everything else disabled.
gremlin1234
posted on 24/7/15 at 04:50 PM Reply With Quote
would the lighter car need a servo?
villagehoppa
posted on 27/7/15 at 07:16 AM Reply With Quote
I was thinking of it weighing something in the region of 7 to 800 kgs, would that need a servo or just use a master cylinder?
Slimy38
posted on 27/7/15 at 10:55 AM Reply With Quote
Plenty of older production cars weigh more than that with no servo assistance.... how strong is your right leg?
