Volvorsport
posted on 6/12/04 at 04:58 PM |
B230 volvo engine .
just for you guys , something to think about - a different engine than , ford , toyota etc . In NA trim this motor produced 200 - 210 hp on twin 45s
, with more to come with cam timing , and ignition timing to play with .
oh , and the torque 190 ft/lbs - something that those engines would love to achieve .
http://homepage.ntlworld.com/mj.slater/video002.avi
http://homepage.ntlworld.com/mj.slater/video003.avi
regards![](/images//smilies/tongue.gif)
gazza285
posted on 6/12/04 at 05:12 PM |
Quick question for you Mr Volvosport. Do the five cylinder engines share the bell housing bolt pattern with the B series motors? Loved the tug of my
940 Turbo, but I'm quite fond of the 2.5 20v Nasty too.
Volvorsport
posted on 6/12/04 at 05:25 PM |
hah , no they dont , although if you find a 6 cyl engine with a manual box , that has the same bolt pattern as the 4/5/6 cyl whiteblock which is a
shared engine platform between all the volvo models .
therefore possible to fit a 5 cyl in RWD car EDIT an M90 is desirable for power capabilities
incidentally the next engine on the dyno is a 5 cyl T5 engine , big rods , capable of 500 hp , well im hoping without mechanical malardies .
the T5 engine capable of 300 hp , about same weight as a reblock 4 cyl , in the video , could prove some interesting performance figures , and in fact
, since that engine is right next to my locost chassis - its getting very tempting .
[Edited on 6/12/04 by Volvorsport]
posted on 6/12/04 at 07:06 PM |
A friend of mine just bought an 850 2.5 20v as a winter hack. The 5 cylinder engine sounds very sweet, and goes well. I've never been a Volvo
fan, but it really impressed me for the money.
How heavy is the engine? Alloy or iron block? Is it an expensive engine to tune/rebuild?
Mike
Volvorsport
posted on 6/12/04 at 07:30 PM |
its no heavier than a 4 cyl turbo engine , ill try to get it on some weight scales soon , its all alloy . They can be expensive if buy all bits from
volvo . when turboed though , you dont have to do much to get em to 300 - or thereabouts its easy to 275 -280 . some chip manufacturers claim 305 hp
, which can be done with a mish mash of std parts (C70 turbo(19 T)) and a bigger exhaust . the 2.5 comes in at 170 bhp . Rods are the limiting factor
initially , those can be done for about £1500- £2000 with new pistons - that should see you get well over 400 hp . I flowed and fitted a skimmed
cylinder head , with 3 angle valve seats ect - for £600 - weve had some reprofiled cams done - but for road use the motor revs past 6500rpm , so
there isnt a real lot to do . the best thing tho is a good EMS , good fuel and ignition control is key to a good tune .
posted on 6/12/04 at 10:52 PM |
Thanks for the info. Do you know if the engine has been used in any locost/seven type application?
Volvorsport
posted on 6/12/04 at 11:11 PM |
i know the 4 cyl has in sweden and abroad , for the 5cyl , you might have height problems , i dont know of anybody doing it , but as soon as i get my
engine crane sorted ill be popping it in there for a trail fit - in fact some measurements of mine seem to say it will fit in there .
it has been used in the back of a darrian for a couple of seasons now .
phelpsa
posted on 7/12/04 at 01:46 PM |
We've got a five cylinder volvo.
It is very torquey and revs all the way up to 4500 rpm.
It's a diesel!![](/images//smilies/bigsmile.gif)
Adam
gazza285
posted on 7/12/04 at 03:36 PM |
I think you'll find it's a VW Adam.
phelpsa
posted on 7/12/04 at 10:38 PM |
Nope, defo a Volvo, it even has the tweed hat to prove it![](/images//smilies/bigsmile.gif)
Volvorsport
posted on 7/12/04 at 10:47 PM |
no , the engine is a vw diesel , unless you got the very latest diesel , which is volvo , i think
phelpsa
posted on 7/12/04 at 10:50 PM |
Yep, it is the latest one, the D5.
And it is made by volvo. The previous 2.5 tdi was made by VW.
Adam
[Edited on 7/12/04 by phelpsa]
Volvorsport
posted on 7/12/04 at 10:56 PM |
they are also very sluggish , remedied by a rica chip , although i hate saying that name and company .
phelpsa
posted on 7/12/04 at 10:58 PM |
Still, if your buying a diesel volvo estate you don't tend to worry about performance,
unless of course your name is Volvosport
Volvorsport
posted on 7/12/04 at 11:24 PM |
well yes , you are correct , but that upgrade is actually used by volvo because of complaints - it goes someway to addressing the drive by wire
sluggishness aswell
svinto
posted on 7/12/04 at 11:57 PM |
Here's a swedish locost build with a Volvo T5 engine:
http://www.mhk.lu.se/home/staffanl/
gazza285
posted on 8/12/04 at 09:32 AM |
I stand corrected. Can't be a bad thing, not using a VW diesel, not exactly known for their reliability.
Volvorsport
posted on 8/12/04 at 11:34 AM |
hmmmm , that originally had a B230 in it - that blokes got mail!!!
posted on 8/12/04 at 07:31 PM |
It's a bit of a squeeze, but then again I've got a big chassis and he's put his radiator in a strange position.
Are the 6 cylinder manual gearboxes you mentioned hard to get hold of?
Volvorsport
posted on 8/12/04 at 07:38 PM |
well , if you do the usual trawl through ebay , since all were top of the range, most are auto - ive only seen one or two manuals - and they usually
go much cheaper for some reason !!(well we know its because autos are better for the green welly brigade) . You might have to source one from sweden ?
look all over the uk for one .
For me though - i would make an adapter plate and use a getrag or T5 (cossie box)
im just trying to sell my 260 box on ebay -nobody even wanted it for £40.
the problem is the box you really want should have a detachable bell housing to make use of it or it could become complicated - as soon as im fit
enough , ill try my 260 box on this T5 engine ive got lying about to make sure the input shaft is long enough . If you want an adapter - like me ,
ill get mine made from the template used to bolt this T5 engine to the dyno.
Zaphod
posted on 11/12/04 at 12:18 AM |
Hey Volvosport
In the promised land of Volvo, did you know that there's a Volvo based Locost manufacturer?
Dala7
Only in Swedish but theres a few pretty pictures to look at
[Edited on 11/12/04 by Zaphod]
Volvorsport
posted on 11/12/04 at 12:40 AM |
ah yes , all based on 140 series , with later back axles .
www.dbsmotorsport.co.uk
getting dirty under a bus
Zaphod
posted on 11/12/04 at 01:00 AM |
Nope, It's based on 700 series, with 140 spindels and 240 steering. The rest is all 700 series.
Volvorsport
posted on 11/12/04 at 02:41 PM |
i think thats what i meant - 140 front suspension and 7 series later running gear .
Nice link anyway - ill be contacting them about stuff soon !
Lawnmower
posted on 20/1/05 at 10:25 PM |
found this:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7949000549&category=33615&sspagename=WD2V
