Neilwilson
posted on 25/7/15 at 06:43 PM |
2.0 Zetec Blacktop Inlet
Hi guys, looking for an inlet manifold setup of some kind for a 2.0 blacktop zetec. Planning to go supercharged route after IVA so anything is
considered.
posted on 25/7/15 at 06:56 PM |
Just go on eBay and search Focus inlet, there's plenty on there.
ianm67
posted on 25/7/15 at 07:40 PM |
considered.
I've got a standard inlet (with injectors / rail etc) you could have for £20 posted?
Always biting off more than I can chew.....
Neilwilson
posted on 25/7/15 at 07:44 PM |
Apologies, I have a standard one but my steering linkages interfere. Ideally want to go for throttle bodies. I have seen some pre-fabbed adaptor
plates on eBay but there quite expensive. Just thought I'd ask on here to see if anyone had something similar.
madteg
posted on 25/7/15 at 07:58 PM |
This is a picture of mine, i used the early manifold that bolts on the head with the injectors in it. I found that the yellow 440cc injectors of a
impreza fit straight in. Found a singe throttle body the wright size and fabricated the plenum, works a treat 330 BHP at the wheels. So to go
supercharged all you have to do is change the injectors. I also have a spare injector manifold.
big_wasa
posted on 25/7/15 at 08:07 PM |
I have a Gbs plenum. Forward facing. Has two throttle bodies two sets of injectors. The injector plate is already modified. Complete and ready to fit.
I've changed my mind.
£160 +post
[Edited on 26/7/15 by big_wasa]
Neilwilson
posted on 25/7/15 at 08:23 PM |
U2u sent for more details.
Thanks guys
