Author: Subject: Breather type 9 gearbox
Rena
posted on 31/7/15 at 04:48 PM Reply With Quote
My type 9 gearbox starts leaking oil from the propshaft input and the speedo output.
First of all before taking the engine out I need to see if the gearbox breather/ventilations is working.
The problem is, I have no idea where the breather hole should be? Could anybody show me on a picture where to find it?
THANKS!
ianm67
posted on 31/7/15 at 05:29 PM Reply With Quote
If you have the original cover plate on your gearbox, it should have a bump / dome pretty much in the middle of it. This should have a small hole in it. This is your breather......
Always biting off more than I can chew.....
itsawindupuk
posted on 31/7/15 at 11:08 PM Reply With Quote
I had exactly the same problem with my type 9. I had enough space to bend a paper clip and feel across the lid. I unblocked the tiny hole at the top of the dome in the centre of the lid and it stopped leaking.
Rena
posted on 1/8/15 at 07:17 AM Reply With Quote
Thanks!
Will check next time I'm at the garage.
Rena
posted on 5/8/15 at 12:01 PM Reply With Quote
Is it this little dome? There should be a little hole in this?
ianm67
posted on 5/8/15 at 01:11 PM Reply With Quote
Yep..... Looks like your lid has been modified and a breather pipe fitted....
Rena
posted on 5/8/15 at 01:13 PM Reply With Quote
That´s not mine - just a picture I found on the web.
Then I will check next time.
Rena
posted on 10/8/15 at 08:09 AM Reply With Quote
Found the hole, unfortunately it wasn´t blocked so I have to take the engine out and change sealings.
