Rena
posted on 10/8/15 at 08:47 AM |
Type 9 leaking - partlist wanted
I forgot to change sealings when I build my car and now it´s leaking from speedo output, input and output shaft.
To solve the problem I have to change the seals but I´m also considering to remove the speedo drive.
Found this
http://www.ebay.co.uk/itm/TYPE-9-AND-ROCKET-SPEEDO-BLANK-WITH-O-RING-SEALS-CATERHAM-WESTFIELD-KITCAR-Etc-/151770036860?hash=item235632fa7c
That´s a nice solution but also a expensive one. If I want to remove the speedo drive and blank the output. Which parts do I need (links)?
MP3C
posted on 10/8/15 at 10:21 AM |
I just had this problem a few months back. My gearbox still has the speedo in just it has been cut off and sealed with a rivet. The leak was from
where it joined the gearbox. All I did was take the circlip out and speedo out and and put some instant gasket on the face and put the speedo back in.
Works fine now and no leakage.
Matt
Rena
posted on 10/8/15 at 12:45 PM |
Matt
That also a solution, but I have change other sealings aswell, that´s why I thought about doing the speedo properly.
