Author: Subject: S shape bracket help
omega0684
posted on 17/8/15 at 08:54 PM Reply With Quote
Hi guys,
I hope you are all well? its been a while again since I last posted but I am plodding along in the background trying to get the car finished.
i've come a little bit stuck with my header tank position and the only way i can get around the lack of space is to mount the header tank at the end of the pedal box, in order to do that i need two brackets (below). i have tried a few options this evening but nothing seems to be holding with what i have lying about in the garage.
i would imagine that 3/4mm ali should be strong enough, is there anyone on the forum who would be able to make me a pair?
dilley
posted on 17/8/15 at 09:26 PM Reply With Quote
Are you sure it will be high enough? I'll see if a friend of mine can make the brackets....
omega0684
posted on 18/8/15 at 04:55 AM Reply With Quote
Hi there, thanks for the quick response
Yes, it should be high enough, with the header tank mounted at the top of these brackets the return pipe from the top of the rad is above all other pipe works
[Edited on 18/8/15 by omega0684]
