If you are looking to put this in a lsis in rwd config then iirc this is one of the hondas that turns the opposite way to normal so finding a gearbox
will be tricky.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Ifyou are looking fir something different, I always wondered if the lexus is200 2.0l straight six would fit. 170hp and a free six speed box. But for
value a 1.8 mx5 with an eaton blower must be pretty high on the list, a number of conversions around.
will be tricky.
Anyone know how to get an anti-clockwise Honda engine in a RWD kit car? I love the B18C in my Integra Type R, I think it'd make a cracking
choice for a se7en. But what gearbox and diff?
I will have a look into the Lexus, any idea of approximate price of the blown MX5 install?
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me." Hunter S Thompson
I imagine getting the engine and charger is the easy/cheap bit, all the ancillaries and mapping will bump the cost up to something like £2-3k as a
wild guess.
Another option is the Beams 3SGE Toyota engine that is in the celica/MR2/Altezza, in the Altezza it comes with the 6 speed RWD box. Apparently quite
tall but looks like it works well with thottle bodies going by some YouTube dyno runs. There is a Seven with it in on there.
If you go for the BEAMS 3SGE get the Altezza variant, not a Celica/MR2.
The Altezza type is already RWD, the others will need LOTS of work to convert to RWD.
I have done a 3SGE RWD conversion for my car and would definitely go the Altezza route if I was starting again.
I can also vouch for the AZ6 six speeder, having just fitted one to my car.
The 3SGE is a cracking engine.
The BEAMS variant is 210bhp standard which is plenty.
quote:Originally posted by Fandango
Just stumbled across a complete Honda Accord Type S (2004) 7th generation 2.4 making 188hp.
Anyone here used this engine?
That's a K20A4, effectively the Integra/Civic Type R engine but in a lower state of tune. It's been used in quite a few 7 style cars, but
it's a tall engine so a dry sump may be called for.
Sadly the 6 speed box from an S2000 uses a different bellhousing bolt pattern to the K20 lumps, so the gearbox is still a problem.
