Author: Subject: Classic mini "Mini spares" timing belt......
anthony1
posted on 2/9/15 at 08:37 PM Reply With Quote
I have just purchased a Mini 1293 "race" engine for sons Cooper S replica........it is fitted with a cam belt kit , it uses a GATES 195L075 belt , after a quick call to Minispares for a spare , I was told they were no longer made.......fit a duplex chain instead !! not really what I wanted to hear! can anyone point me in the direction of a supplier for these......they are widely still available in the USA.....but after adding postage are not at the moment a cost effective option.
ken555
posted on 2/9/15 at 10:51 PM Reply With Quote
Here ?
Minicooper
posted on 3/9/15 at 09:53 AM Reply With Quote
This place sells the belts
http://www.shengineering.co.uk/sh/content/mini-timing-belt-kit
chillis
posted on 3/9/15 at 11:15 AM Reply With Quote
Try contacting Gates directly to see if the belt is still made, if it is they should be able to give you a list of suppliers.
Never under estimate the ingenuity of an idiot!
posted on 3/9/15 at 12:01 PM Reply With Quote
That looks like a much better thought out kit than the minispares one as it actually includes a tensioner. Since the primary advantage of the timing belt conversion was to prevent the (significant) timing scatter that a stretched chain introduces, it doesn't make much sense to leave out the main component that would effect that improvement.
A cheaper option is to fit the A Plus chain drive that includes a tensioner, and can be used in conjunction with a duplex chain (which is what I had fitted to my mini many years ago).
907
posted on 3/9/15 at 12:55 PM Reply With Quote
Possibly Fenner do a compatible belt.
They have distributors all over the country. Gateshead might be near you.
Paul G
anthony1
posted on 3/9/15 at 03:40 PM Reply With Quote
Cambelt......hopefully sorted.....
Many thanks for all of the replies........I have spoken to Dave at SH Engineering , what a great bloke! very helpful and knowledgeable. he has the belts available.
posted on 3/9/15 at 06:51 PM Reply With Quote
Any decent motor factor should be able to help,
