Author: Subject: chopsaw u get what u pay4
kaymar
posted on 8/12/04 at 10:30 PM Reply With Quote
cautionary note screwfix sell a mini chopsaw only 39.99 a neat compact thing?but do not sell replacement discs @150 x2.5 x22.2 mounting and guess what nobody else seems to oh BUGGER. I only managed to get ten cuts out of it and its bottomed out martin
stevebubs
posted on 8/12/04 at 10:45 PM Reply With Quote
150mm = 6".
You've probably already looked at this, but would 6" grinder metal cutting discs not fit (available from local DIY store)?
[Edited on 8/12/04 by stevebubs]
kaymar
posted on 8/12/04 at 11:28 PM Reply With Quote
well the problem lies in the spidle centre@22.2 which is usually for 300+ discs and most small angle grinders are between 115 &125 not 150 they then start up again at 180. i have been given a disc to try 150 x3.2!!! not sure if the motor will like spinning through material though. thanx for the thought
stevebubs
posted on 9/12/04 at 12:08 AM Reply With Quote
I believe there are 15mm-22mm spindle adapters out there.
Let us know if you find a source of suitable discs.
Stephen
posted on 9/12/04 at 09:32 AM Reply With Quote
There are 180x22.2x3mm blades available and various sizes in stainless cutting discs with the 22.2mm centre.
http://www.johndavies.co.uk/nabdisc.htm
The AS30 flat at the bottom of the page sound favourite. The centre spindle adaptors usually go the other way to what you need on this occasion.
[Edited on 9/12/04 by Peteff]
mattpilmoor
posted on 15/12/04 at 08:41 AM Reply With Quote
I've just bought a 150mm grinding disk with a 22.2 bore from B&Q warehouse!
Hope this helps.
Matt
wilkingj
posted on 15/12/04 at 01:00 PM Reply With Quote
Chop saws
I believe I got MORE than what I paid for. I CANT COMPLAIN for £27 Plus £6.50 postage - Good Old Ebay.!!!
NEW Chop saw I bought
[Edited on 15/12/2004 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
kaymar
posted on 17/12/04 at 10:50 PM Reply With Quote
got them
found a very good supplier in gloucester who seemed to have thousands of different types of abrasive materials from a sheet of sandpaper to abrasive coating dust to huge grinding discs bought 25 sanding discs for angle grinder for a fiver and 5 discs for chop saw for six pound contact garmur abrasives 01452527665
