Author: Subject: Parts for sale ,rear disc set up,diffs. busa manifold and can
peter bland
posted on 12/9/15 at 06:29 PM Reply With Quote
Sierra rear discs , calipers and brackets. After £150 plus postage.
Also have 3.14 sierra dif and 3.92 diff. Both have push in shafts and are non lsd types.
After £300 for the 3.14 and £100 for the 3.92 plus postage.
Megabusa standard exhaust manifold and silencer, £190 plus postage.
Any questions then get in touch.
Angel Acevedo
posted on 12/9/15 at 10:07 PM Reply With Quote
Free Bump..
How the h3ll did you managed to get the calipers so shiney??
Thanks in advance and good luck with sale...
AA
Zetecron
posted on 19/11/15 at 11:38 PM Reply With Quote
Is 3.14 still available?
peter bland
posted on 20/11/15 at 08:43 AM Reply With Quote
Hi, yes it's still available.
femster87
posted on 20/11/15 at 10:18 AM Reply With Quote
Will you sell the caliper brackets alone?
Mk1rally*
posted on 21/11/15 at 08:42 AM Reply With Quote
Are they 2wd cosy calipers? And do they have the sliders?
peter bland
posted on 21/11/15 at 08:55 AM Reply With Quote
Hi femster87, want to sell as complete kit .
peter bland
posted on 21/11/15 at 08:58 AM Reply With Quote
They are not cosy calipers but do have sliders.
Crispy
posted on 24/11/15 at 12:51 PM Reply With Quote
Does the silencer have an integrated catalyst, and if it does would you consider selling it separately to the manifold? If the answer to both of these is a yes then let me know what price you'd be willing to let it go for.
peter bland
posted on 24/11/15 at 04:38 PM Reply With Quote
Hi, it doesn't have a catalyst.
danny keenan
posted on 24/11/15 at 04:52 PM Reply With Quote
Fester
I have the brackets in stock and your only down the road.
http://www.mksportscars.com/parts-c3/brakes-c4/disc-brake-adaptors-p30
Thanks Danny
mk7matt
posted on 3/12/15 at 07:10 PM Reply With Quote
Just wanted to say 'thank you' to Peter.
Parts arrived well packed and as expected.
Now to get my MK back together for the spring.
rj
posted on 3/12/15 at 08:10 PM Reply With Quote
hi, is the manifold still for sale? if so could you take some measurements of the port spacing and the diameter of the bit that goes into the exhaust port. I need a manifold to fit a ZX12r motor, suspect a busa one isn't far off !
peter bland
posted on 4/12/15 at 07:12 PM Reply With Quote
Hi, first chance to check sizes, apologies.
The Manifold end is 45mm ports with 90mm centers.
The silencer is 2 1/2 in .
Cheers Peter
mcerd1
posted on 4/12/15 at 09:28 PM Reply With Quote
Bit late, but cossie 2wd calipers are the same as normal Sierra ones
Its just the mounting lugs on the hubs that are longer to suit the bigger discs
(ie there are only 2 kinds of caliper, one for vented discs, the other for solid discs)
[Edited on 4/12/2015 by mcerd1]
