ragindave
posted on 23/9/15 at 09:21 AM |
SOLD !!Burton Power Edge gear reduction starter: Ford CVH/Zetec
For Sale
£100 including P&P
Edge CF007 gear reduction starter: Ford CVH/Zetec E 1.4kw
Reduction geared, lightweight, high torque starter motor. Designed to start any engine regardless of compression or engine temperature. All starter
motors are a straightforward replacement for the original unit.
• Gear reduction gives 200% more cranking torque.
• Uses 50% less current than original starter.
• Ideal for use with small gel batteries.
• Compact & lightweight.
• Uses direct acting solenoid.
See link below for full details
http://www.burtonpower.com/catalogsearch/result/?q=CF007
[IMG]http://i110.photobucket.com/albums/n81/ragindave/20150906_122449.j
pg[/IMG]
[IMG]http://i110.photobucket.com/albums/n81/ragindave/20150906_122518.j
pg[/IMG]
[IMG]http://i110.photobucket.com/albums/n81/ragindave/20150906_122536.j
pg[/IMG]
[Edited on 23/9/15 by ragindave]
[Edited on 24/9/15 by ragindave]
HowardB
posted on 23/9/15 at 10:36 AM |
interesting, which way round is it,... when viewed from the nose does the solonoid sit up or hang down?
thanks
Howard
ragindave
posted on 23/9/15 at 11:35 AM |
Some more pictures added I hope that helps.
HowardB
posted on 23/9/15 at 02:44 PM |
I'll check and get back to you, need to make sure it doesn't foul on something,.
Howard
ragindave
posted on 23/9/15 at 03:53 PM |
Thanks Howard it is under off from another locoster via u2u but I think you will find this fits FWD Zetec or CVH not type 9 or MT75 to Zetec rear
wheel drive as thats what I thought it fitted when I purchased it!
HowardB
posted on 23/9/15 at 07:38 PM |
thanks for the info, FWD is no good for me
oh well, it looked so shiny too. Good luck with the sale
Howard
Howard
