Author: Subject: Do steering racks have a centre point
steve m
posted on 29/9/15 at 08:57 AM Reply With Quote
Maybe a stupid question, but, do steering racks have a centre point
as in it should be centralised before attaching tie rods etc
mines a n escort mk2 quick rack
steve
rodgling
posted on 29/9/15 at 09:11 AM Reply With Quote
Just measure halfway between the two end points?
SJ
posted on 29/9/15 at 09:17 AM Reply With Quote
As above, just count the turns lock to lock and then stop half way.
Stu
cliftyhanger
posted on 29/9/15 at 09:18 AM Reply With Quote
Some do (or did) but I have limited experience.
On those that don't, I turn to full lock one side, and count turns to full lock the other. Turn back halfway and that is central.
Must say a drilled hole would be dead handy to get it exact.
Smoking Frog
posted on 29/9/15 at 10:02 AM Reply With Quote
Yes, the rack should be centralised (ignore steering wheel position while doing this and refit after).
gremlin1234
posted on 29/9/15 at 10:37 AM Reply With Quote
small triumph ones do,
remove the grease nipple, insert small (2mm wide) screwdriver, and there's a dip at the centre point.
else
rather than counting turns on the wheel, I would measure the end of the rack on max left, and max right, and take the halfway point
steve m
posted on 29/9/15 at 10:40 AM Reply With Quote
Thanks guys
steve
garyo
posted on 29/9/15 at 02:57 PM Reply With Quote
You'll never quite get the bump steer right if you don't have it centralised, but that's all in the fine tuning really.
hizzi
posted on 29/9/15 at 09:04 PM Reply With Quote
just did my own escort quick rack today, i turned it fully one direction , marked with marker pen and counted the turns then centred from there. funnily enough its a 2.9 quick rack equates to 2.9 turns
