New Topic New Reply
Author: Subject: Gaz coilovers
shane159
posted on 3/10/15 at 02:57 PM Reply With Quote
Gaz coilovers
Hi Guys,
I've had a little blond moment today and caught the front wheel on the kerb bending the shock on one side, does anyone know what shocks are fitted to a MK Indy or can anyone point me in the right direction where to get a single or two fronts from?
maccmike
posted on 3/10/15 at 03:27 PM Reply With Quote
Gaz?
JacksAvon
posted on 3/10/15 at 03:37 PM Reply With Quote
http://www.gazshocks.com/
Dick
posted on 3/10/15 at 03:46 PM Reply With Quote
Protec did supply mk for a good few years
ian locostzx9rc2
posted on 3/10/15 at 03:54 PM Reply With Quote
Best to take it off and measure it if you have bent the shock you may have bent a wishbone as well ??
shane159
posted on 3/10/15 at 04:04 PM Reply With Quote
Thanks guys, yeah the wishbone is bent also
CosKev3
posted on 3/10/15 at 05:27 PM Reply With Quote
Have a very good look at the wishbone mounting points onto chassis.
MK supply Protec now,but used to use Gaz.
b3ngy
posted on 4/10/15 at 11:12 AM Reply With Quote
If its a Gaz damper the part number on the shock will tell you the open/closed length of the damper. Have a look on rally designs.
alfas
posted on 4/10/15 at 05:45 PM Reply With Quote
any brand could be used by the builder....best is to post a pic
shane159
posted on 4/10/15 at 05:57 PM Reply With Quote
Thanks for all the help guys, I've just removed all the parts and to be honest I've been really lucky, the wishbone took all the force meaning the mounting points are still as they should be, the shock isn't actually bent but cracked at the bottom, Unsure if his could be salvaged or not.
Badger_McLetcher
posted on 4/10/15 at 08:02 PM Reply With Quote
I probably wouldn't try repairing that shock, not much meat for a new weld. Definitely get a new wishbone though!
If disfunction is a function, then I must be some kind of genius.
shane159
posted on 4/10/15 at 08:15 PM Reply With Quote
Yeah already ordered a new wishbone and gonna order 2 shocks also.
Angel Acevedo
posted on 5/10/15 at 02:32 AM Reply With Quote
There´s been discussion about strength of wishbones.
this clearly show that wishbones should be "disposable" to save chassis and lives...
My humble point of view...
AA
shane159
posted on 5/10/15 at 07:41 AM Reply With Quote
AA
I'm with you on that one!!!
shane159
posted on 8/10/15 at 07:42 PM Reply With Quote
I'm glad to say the Indy is back together again, until the weekend anyway when the engine is coming out for the gearbox to be refurbished, once all built up then off for a fresh geometry set up, can't wait now.
Big thanks to MK Sports cars for the excellent customer service & speedy delivery.
Samuele
posted on 3/6/16 at 10:19 AM Reply With Quote
s
New Topic New Reply
