Theshed
posted on 9/10/15 at 06:33 PM |
Crimper help
Wiring time…..
I am using a fully crimped loom. I have a crimper for Autosport contacts but need one for Tyco Cold splices, Junior timer contacts and the contacts on
the Motec ECU?? Is there a frame crimper that will do the lot or do I need to scour ebay? Any recommendations anybody?
If anybody wants to crimp Autosport connectors then drop me a line if I am not using crimpers I will lend against a sensible deposit.
40inches
posted on 9/10/15 at 08:10 PM |
Anything here?
blakep82
posted on 9/10/15 at 08:28 PM |
a seller on ebay, called leomax122 or something similar (definitely leomax, not sure what number follow) sells crimping tools, usually under £10 each,
same ones you buy anywhere else, great tools for the money. a bit difficult trying to find the right one, but when you find it, they work perfect.
just as well as the same thing for £40+post
________________________
dave
posted on 10/10/15 at 09:46 PM |
Try Pole Volt, they have a range of crimping tools to suit almost all connectors.
