Author: Subject: Does r1 Big Bang need baffled sump in MK
Bigbangmkindy
posted on 10/11/15 at 07:34 AM Reply With Quote
Well pretty much just as the heading says does the r1 need a baffled sump ? If so where can j get one ? Thanks
CosKev3
posted on 10/11/15 at 08:28 AM Reply With Quote
Most bike engines require sump/baffle plate/dry sump systems so I would guess it will need something!
Have you asked MK?
Only MK I've seen with the big bang R1 is on YouTube, the air box sticks up out of the bonnet like a block of council flats!!!
Be good to see pics of your build, as it's not a common engine to use.
Bigbangmkindy
posted on 10/11/15 at 08:42 AM Reply With Quote
Yeh Iv seen his vids it does sit high lol seems to go well though !
gaz_gaz
posted on 10/11/15 at 08:53 AM Reply With Quote
Big bang is partially baffled, Malc at Yorkshire engines reckons no baffle is required but I'd be looking at belts and braces myself,
The engines sound incredible and If you're not chasing lap times in a race r or the like then the little dip in power shouldn't matter,
There's a fella putting a crossplane engine into a mini on this forum, Cant remember his name but a search may turn up so helpful info for you!
Bigbangmkindy
posted on 10/11/15 at 09:01 AM Reply With Quote
It does sound Gd only got exhaust still to sort out but Iv managed to give it a wee run to see how it's going and performance wise it's feeling way more powerful compared to the 918cc fireblade that was removed
gaz_gaz
posted on 10/11/15 at 09:02 AM Reply With Quote
lets see some pictures and videos
Bigbangmkindy
posted on 10/11/15 at 09:05 AM Reply With Quote
http://youtu.be/wPj389-Yvn4
Bigbangmkindy
posted on 10/11/15 at 09:21 AM Reply With Quote
Realy couldent get any power down think the highest rpm I got to was only about 8500
CosKev3
posted on 10/11/15 at 11:48 AM Reply With Quote
Ha ha bet your neighbours love you!!!
Have you got a lsd in the back or open diff?
Bigbangmkindy
posted on 10/11/15 at 11:55 AM Reply With Quote
Lol to be honest next door are very understanding lol
Bigbangmkindy
posted on 10/11/15 at 11:56 AM Reply With Quote
And I'm running a 3.92 ford LSD
CosKev3
posted on 10/11/15 at 12:03 PM Reply With Quote
Your brave giving it that much throttle on a wet road!!!
What top speed will you hit with a 3.92?
just changed mine to a 3.38 as my 3.62 was making mine horrible to drive at 60 - 70mph due to the high revs,topped out at 120 mph.
Bigbangmkindy
posted on 10/11/15 at 12:09 PM Reply With Quote
Well mine was redlining at 104 with the blade engine but should be more like 125mph now with me extra 2500rpm
Johneturbo
posted on 10/11/15 at 01:27 PM Reply With Quote
Good to see something different like the crossplane crank
Was your clutch slipping through that housing estate
Bigbangmkindy
posted on 10/11/15 at 01:41 PM Reply With Quote
No no that was just wheel spin mate clutch is feeling pretty Gd ! I will upgrade it but first things first exhaust is the next thing to get on with
Bigbangmkindy
posted on 10/11/15 at 01:47 PM Reply With Quote
