Author: Subject: Electrolysis rust removal and chrome
r1_pete
posted on 14/11/15 at 07:08 PM Reply With Quote
I have a motorcycle rim on which the visible chrome is perfect, huwever the back where the tyre fits is rusty.
I was thinking of electrolysis using a curved bar following the cyrve of the rim, going around the rim in segments.
Question is, will it effect the chrome? I understant electrolysis effectively works 'line of sight' but just wondered if there was a chance of wrecking the chrome which would be on the opposite side of the rim to the metral bar....
Cheers.
Pete.
mini-sprite
posted on 14/11/15 at 07:24 PM Reply With Quote
I've cleaned loads of rusty parts through electrolysis but haven't put anything with chrome in the tank. I would of thought if there was a chance of the electrolyte getting under the chrome and finding some rust then it would remove/change the rust and risk bubbling it.
Paul
MikeR
posted on 14/11/15 at 08:27 PM Reply With Quote
Doesn't the solution have a nasty reaction with stainless producing something poisonous? If I'm right I'd be careful about chrome in case their is a similar outcome. Have you tried searching the internet, someone has bound to have done it.
r1_pete
posted on 14/11/15 at 09:55 PM Reply With Quote
Cheers guys, i did google it and found nothing.
I guess a mechanical removal will be safest....
Barlidge
posted on 14/11/15 at 11:22 PM Reply With Quote
As above, although from memory I believe its when stainless/chrome is used as the anode.
Build Diary: http://www.roadster-builders.co.uk/forum/viewtopic.php?f=25&t=111
posted on 15/11/15 at 12:25 AM Reply With Quote
I've done a good few brake calipers and no effect on the chrome plated pistons.
Electrolysis only attacks ferrous oxide. If there's any rust under the chrome it will lift it off but that helps identity the problem.
