<<  1    2  >>
Author: Subject: Blacktop or ST170
J90rdn
posted on 19/11/15 at 12:51 AM Reply With Quote
Blacktop or ST170
Apologies as I know this type of question has been asked in various different guises, and I have done some extensive reading via google and the search function on here, but don't seem to have the answer to this specific question.
I'm scratching around looking for a donor engine for the Avon. I've read about the Zetec 1.8 and 2.0, and the ST170 Durance/Zetec engine. I've read about the varying degrees of success with locking the variable cams on the ST engine, and also the £300 little gizmo box which can work the VVT correctly.
My question is, if I was planning on fitting some Kent cams (or similar), could I fit these to the ST engine (so spend money on some cams rather than the £300 VVT gizmo)? Would fitting the cams to an ST engine give me a better engine package than fitting the cams to a blacktop 2.0? Or would I be better off sticking with the VVT option on the ST engine?
Chaz
posted on 19/11/15 at 07:50 AM Reply With Quote
It's up to you as to what a better engine package means?
If you haven't got your car on the road yet I would look for the simplest and cheapest (value) deal is. All 4 engine (I think) share similar stud patterns for mounts, inlet and exhaust which means they are interchangeable (not 100% on the ST). All will produce 'similar' power if you're not going for s/c or turbo. If I had my first build time again I would get it in the road then buy another zetec and make it up whilst having a running car to play with. In short I wouldn't bother with the ST, buy a Blacktop 2.0 with descent cams will be a good first drive.
J90rdn
posted on 19/11/15 at 08:07 AM Reply With Quote
Should have said, this is pure track car. It will get some abuse. Was wondering if the St engine was stronger and better engineered?
I already have the exhaust and inlet manifold, along with engine mounts. Have a few months to get it ready for the track season in 2016.
big-vee-twin
posted on 19/11/15 at 11:59 AM Reply With Quote
Duratec ST150
http://www.triangleltd.com
Adamirish
posted on 19/11/15 at 12:32 PM Reply With Quote
Generally the ST170 motor is a stronger engine especially if you want to exceed 7000rpm. They have better, lighter pistons and stronger rods. As standard they rev to 7400 and with arp rod bolts are good for 8000rpm. They also have a bigger valve head and also flow better than the blacktop. The only problem is cams. As far as I know only one company make them for the st motor. Cat cams. Great power gains and over 200 hp with jenveys. Down side is they are expensive at £800 a set!
MK Indy 1700 Xflow
J90rdn
posted on 19/11/15 at 04:00 PM Reply With Quote
Piper cams have them listed, but not sure if that is a direct replacement, and if it includes the VVT delete kit (doubtful). Will try calling around tomorrow.
I like the idea of a stronger, slightly enhanced head. If I'm going to do this, and the ST170 engine would be a better proposition but just slightly more expensive, then I'd potentially rather explore that option.
big_wasa
posted on 19/11/15 at 04:39 PM Reply With Quote
The st170 is a better engine to start with but as always there are pros and cons.
The st170 has better pistons and rods but they are NOT forged. The rods have bigger big end cap bolts. The engine has a higher Cr ratio. The head has bigger valves and ports.
The heads are weaker not stronger and are less forgiving of overheating.
Base engines are popular at the moment and full engines are starting at £300+ Small potatoes in the scheme of things but you can get three or four zetecs for that.
To get the same power from a zetec would require head porting and cams.
Adamirish
posted on 19/11/15 at 05:00 PM Reply With Quote
There is what looks like a good ST motor on eBay at the moment as it happens. It sounds expensive at £4250ono but, it comes already built with cams, headwork, forged pistons and rods, 48mm jenveys, loom and ecu. 237bhp. Apparently only done 600miles too. Considering the tb's and ecu is the best part of £2k I don't think it's bad value.
Ford ST170 Zetec Engine Cat Cams Jenvey Mk1/2 Escort Fiesta Blacktop
Edited to add link
[Edited on 19/11/15 by Adamirish]
MK Indy 1700 Xflow
J90rdn
posted on 19/11/15 at 05:11 PM Reply With Quote
Edited to add link
You've got me sold, but you'll need to run it past the financial director for final approval. She's back from work at 6 and is likely to be in a bad mood. You up for a challenge ;-)
Adamirish
posted on 19/11/15 at 05:19 PM Reply With Quote
Edited to add link
It's such a shame I go to work at 6pm! I would love to help you otherwise mate. Cook her dinner and buy her flowers. I don't know why I'm telling you that, it never worked for me!
Try the "look how much money we would be saving rather than building it myself" line. That probably won't work either so good luck, you are on your own!
MK Indy 1700 Xflow
J90rdn
posted on 23/11/15 at 02:04 PM Reply With Quote
Originally posted by big-vee-twin
Duratec ST150
Missed this one. What are pros and cons? I do already have Zetec mounts and manifold, but I guess they could be sold.
Paul Turner
posted on 23/11/15 at 03:23 PM Reply With Quote
The newest ST170 engine will be 10 years old and will probably have been thrashed for most of its life. Its likely to need a decent amount of money spending on it to make it reliable for the future.
Similar with the ST 150 engine but it is a bit newer.
Or you can buy an unused crate Blacktop for under £1000. Sell off the bits you don't need on e-bay to reduce the price.
With TB fuel injection it will produce about 170 bhp out of the box and if you feel the need a pair of cams and a bit of head work will see it up to 210 bhp with no further mods other than possibly a set of ARP rod bolts.
Guess which I have in mine.
J90rdn
posted on 23/11/15 at 03:45 PM Reply With Quote
Yeah, suddenly remembered I also have a Jenvey Zetec inlet manifold as well, so that would be 3 things that I would need to replace - not worth it I guess.
Am I wrong to think the following? These crate blacktops were about £600 not long ago. It riles me slightly to think that some companies have hoovered these up with the sole intention of sitting on them for a year or so then selling them for a premium. So yes, I like the idea of a new engine, but no, don't like the idea of being slightly (and I guess only slightly) ripped off.
Paul Turner
posted on 23/11/15 at 04:13 PM Reply With Quote
I bought mine about 7 years ago and paid £650 + VAT from Raceline, £780.
Today you can buy one from Raceline for £875, 2000cc Ford Zetec FOCUS Black Top Engine an increase of £95 or 12%, not a rip off is it really.
An alternative is Kit Spares who want £950. But based on how they dealt with issues with a product I bought form them a few years ago I would not deal with them again.
Cheapest I saw when I bought mine was £700 all in but I preferred to buy from Raceline since they give excellent service and assistance.
prawnabie
posted on 23/11/15 at 04:51 PM Reply With Quote
Don't forget that these crate engines are now a minimum of 10 years old, so budget in for a cambelt if you go for one.
Paul Turner
posted on 23/11/15 at 04:58 PM Reply With Quote
Good point, changed mine last year, it was built 2004.
Personally I would not be changing pulleys and tensioners on a new engine, just the belt.
For the record all the crate engines were built 2004 which is when production of the Zetec stopped. Ford had enough stock to see the mk1 Focus out and the Mk2 in 1800 and 2000 forms was a Duratec.
kingster996
posted on 23/11/15 at 05:48 PM Reply With Quote
This is precisely why I will also be buying a crate Zetec (plus new cam-belt) for mine over winter. I actually have a perfectly good ST170 sat in the garage that I heard running before the guy took it out for me.
However - I decided that I'd rather go for a new engine instead of an older one. I'd need some way to do the VVT on the ST170 and so once I factor that in, the crate engine isn't too expensive really.
Anyone want to buy the ST170? Cost me £340 earlier this year open to offers...
[Edited on 23/11/15 by kingster996]
I used to be indecisive, but now I'm not so sure
J90rdn
posted on 24/11/15 at 01:51 PM Reply With Quote
Taking everyones opinions on board, I spoke to a few people yesterday who are selling crate blacktops. Waiting for 1 to reply with a quote, and if a price can be agreed will be going down that route. Priced up a cambelt and seems they are about £22 from euro car parts, so worth doing. Once ordered, will be buying an RX8 gearbox and adapter plate as I fancy giving that a try. The cutting disk will be getting some action on the transmission tunnel over xmas :-)
Will update post with prices etc when all sorted.
Antnicuk
posted on 24/11/15 at 07:20 PM Reply With Quote
the rx8 box will fit with a little cutting and welding
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
J90rdn
posted on 24/11/15 at 07:23 PM Reply With Quote
Yep, thats the idea. Nothing a bit of metal glue won't fix.
johnH20
posted on 25/11/15 at 10:36 AM Reply With Quote
Slightly off topic but why do people think that 'unused' cambelts on crate engines need replacing? They have seen no dynamic stress, only a modest static load, and live in a dark ( no UV ) oil free environment. Not much different to the replacement you might buy that has been on the parts shelf for years. Just interested if anyone has got any evidence on this.
Adamirish
posted on 25/11/15 at 10:48 AM Reply With Quote
The belts have been sat under tension(albeit not a great deal) for x amount of years while the ones off the shelf wont have been.
For the sake of £20 its silly not to change it. It would be a shame to have to rebuild the head on a brand new engine.
MK Indy 1700 Xflow
J90rdn
posted on 25/11/15 at 10:50 AM Reply With Quote
Would the belt not have been under tension for 10 years+, unlike a boxed belt. Plus, I doubt any boxed belt would be over 10 years old.
Replacement is belt and braces. Not sure if this is a safe or interference engine, but for £20 is it worth the risk on a £900 engine?
Adamirish
posted on 25/11/15 at 11:00 AM Reply With Quote
The zetecs are an interference engine. Ask me how I know! If I had of known then what I know now, I wouldn't have put it off for so long.
MK Indy 1700 Xflow
Paul Turner
posted on 25/11/15 at 11:18 AM Reply With Quote
Keeping costs low is one thing. Saving the cost of a cam belt, an item that has a service life and does break is totally stupid.
A cam belt costs less than a fill up with fuel and on a Zetec can last 10 years (mine will be changed earlier) so why on earth would you want to risk it.
One forum I visit has a poster that refuses to accept that cam belts require changing, says its a conspiracy. He inspects his every year and coats it with talc. Says he will change it when he sees cracks.
But he also refuses to accept that oil, brake fluid and antifreeze need changing, again its all a conspiracy. Claims his car, which is 35 years old and he has owned form new is still on its original brake fluid, coolant but has had 5 oil changes.
Total muppet.
<<  1    2  >>
